Need a new camcorder.  Any recomendations?
Started by The Barge Captain, 16 April 2007, 14:34:55
tonycooper
Well....given your requirements.....you need DVD or harddisk....and given that the final required media is DVD......then DVD sounds the best option....as you can copy a disk in 10 mins or so...
HD and DV still have the pain in the arse slow download to a PC.........then onto a DVD (and in the case of DV it has to be re-processed...
Remember people, we are trying to offer a solution to somebodies requirements......were not blowing our OWN trumpets.......as biased as we may be....
Martin_1962
Well I still don't trust DVD as a recording medium.
The Barge Captain
An interesting conversation guys, but i'm still looking for recomendations for something to buy.
I know The Boy is anti Sony but i am considering the following products from them
DCR-SR32E (£320) ,   DCR-SR52E (£360),   DCR-SR72E (£400) ,   DCR-SR190E (£470)
Just need to sit down for a hour and compare specs. :-/
Martin_1962
They all look OK
You need to work out what you want - go for biggest drive and run on highest quality
I do not use DVD camcorders, but for data, generally find DVD to be very reliable - moreso than any tape technology I've come across from a data point of view.  Obviously, crap media is lower quality, so decent media is the answer.
And I've never seen the 'mini explosions' Martin Imber mentions (even with 7p DVDs) - that to me says a problematic drive or very low quality media.
As to which camcorder, if its just for 'family' type stuff, and not semi pro productions, I think you will be happy with anything on the market, be it budget brands or those where you pay a premium for the name.
Martin_1962
Thing is with DVD if it does fail if you are burning off a PC ect you can just do another - once burnt they are OK
Hard Disks are basically extremely reliable.
Modern cameras are not as well made as the early ones so don't expect them to last for ever.
Quote......
Had a look through the laminated book of dreams (Argos) ......
Ah! Another Bill Bailey fan.  ;D  :y  :y
QuoteThing is with DVD if it does fail if you are burning off a PC ect you can just do another - once burnt they are OK
Quality media does bring this to nigh on 100% success.  I tend to use Verbatim for data.  Of the 100s, possibly 1000s of Verbatim I have used, I have never had a burn failure.
Obviously, the cheaper media I use is not as good.
Tapes can be equally unreliable.  Smaller tapes, such as DAT and DV do have a tendency to chew up sometimes ;)
Martin_1962
I find DVDs vary from batch to batch, Ritek G04 were good the newer ones not as good. As to tapes I have played back 1984 tapes, that said the 1987 tapes being better quality were fine!!!!
I do not know how long any modern media will last I think it is best to hedge bets over different types.
Ritek G04 is a dye, not a DVD.  Therefore 'Ritek G04' DVDs can vary from utter rubbish to reasonable (for budget)...
