3.0L Cams - Implications
Started by ClarCE, 17 April 2007, 14:28:07
ClarCE
Hi all,
As some of you are aware I'm going to be fitting (with help) my 3.0L (excellent condition) cams soon, to my 2.5 V6.
What I wanted to know was what implications that this might have on the future - besides things like fuel economy, I wouldn't be doing this if I was remotely bothered about that sort of thing..
What I am thinking about is increased wear, blowing spark plugs out of the wells and destroying the engine, getting heavily pitted pistons and eventual destruction - these kinds of things.  Engine has 101K on it at the moment, what can I realistically expect to get from it by changing the cams over.
Or
Will it do nothing except use more fuel and make me smile more :D
Cheers,
Chris.
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
Remember this.....this engine is pretty much the same as the 3.0 one with the excepetion of the bore and stroke....and Vx sold 2.5V6 power plant with the 3.0 cams fitted in the Vectra GSi......
So its all smiles and no worries...
QuoteRemember this.....this engine is pretty much the same as the 3.0 one with the excepetion of the bore and stroke....and Vx sold 2.5V6 power plant with the 3.0 cams fitted in the Vectra GSi......
Just to hi-jack this thread a bit (sorry Chris)
Mark, can 3.0 cams be fitted to the 2.6? Or do they have to be the 3.2 cams?
Seen a very nice 2.6 MV6 Manual for sale, and if I had the cash would have traded up! I will prob get a 2.6 when I do finally trade up...
I am assuming like the 2.0 / 2.2 the 2.6 is just a stroked 2.5? With a slightly larger bore?
omegaV6CD
QuoteHi all,
Or
Cheers,
Chris.
You strictly need new lifters if you want the Job to be a proper one. Other than that you should have absolutely no issues.
ClarCE
All sounds good, already smiling more :D :D
No worries Tunnie, I do it all the time :P
Would you worry about the lifters then as Omegav6cd suggests Mark?  I didn't really want to be pulling the head to peices to be honest..
QuoteAll sounds good, already smiling more :D :D
You won't be pulling the head to peices
Once the cams are out, the lifters just pull upwards
(a suction device helps!)
Agreed, the lifters would be an easy change with the cams already out but a new set of 24 of them would make this quite an expensive operation.
... but then isn't only one of the cams (Inlet / Exhaust) different between 2.5 / 3.0 in any case .. or did I imagine that?
So presumably one cam and lifters in each bank could stay.
Thats true of the older C25XE but, not the X25XE.....as for the lifters.....I would test and clean them......
ClarCE
Ok, I have a couple more questions following responses:
1.) When cleaning and testing the lifters are there any seals I need to replace?
2.) Part number for 2.5 V6 Lifters incase when testing I find any broken ones
3.) Part number for 3.0 V6 Lifters as I may just replace the lot if not mega bucks...
Cheers again!
Chris.
Matchless
Lifters are the same across all V6 Ecotec engines of the same vintage.
There were some changes around 97/98 which is tied in with a different oil pump which required modified T vents, the lifters also changed to a different construction but that was for reliability, not oil pressure reasons.
When the cams are out you can clean and test the lifters following the guide on here.
Remember when assembling:-
Green sealant under the front cam bearing cap front edges, black sealant in the corners of the camcover seal path but take care to keep the sealant away from the drain holes in the front bearing caps.
ClarCE
QuoteLifters are the same across all V6 Ecotec engines of the same vintage.
Chances are that mine are of the 'changed' variety then seeing as its a 98 car - if I read what you're saying correctly, there is no difference in the lifters between 2.5 and 3.0 varients..
When I've thought about changing them in the past on other engines they've been 7 or 8 quid each. Multiply by 24 and it's expensive.
In theory you should change them with the cam. In practice I think if the lifters are in OK condition I'd leave the old ones in. If I were fitting brand new cams I'd treat them to a new set of lifters.
It may be worth giving them a clean because once crud gets into them there is no where for it to go.
How are the lifters at the moment? Do they quieten quickly after an engine start?
I have heard you can planish the top surfaces with some fine wet and dry prior to re-fitting but not sure I could make them any flatter than a set of decent 100k lifters anyway!
ClarCE
QuoteWhen I've thought about changing them in the past on other engines they've been 7 or 8 quid each. Multiply by 24 and it's expensive.
Mine is a pretty quiet one I think - there is noise there that I can hear, but its not loud - maybe I just have a couple that are knackered...
Maybe I'll buy five of them and take back what I don't use when attempting this job..
Ronald_McBurger
Yeah yeah, you all sound very knowledgable, but has yoiur MV6 got a Homer Simpson that flashes when you brake?
