Author Topic: Elite Aerials  (Read 1119 times)
Elite Aerials
« on: 04 July 2010, 13:54:21 »
Just out of interest, I was looking at the 2 Elites Josh has for sale, why is the Estate aerial longer.
bertiecbx550
Re: Elite Aerials
« Reply #1 on: 04 July 2010, 13:57:31 »
Coz the signal has further to go on an estate than a saloon... ::) ::)
Re: Elite Aerials
« Reply #2 on: 04 July 2010, 15:31:16 »
Noticed that difference between our saloon & estate.
Believe saloon aerial is for phone only - radio aerial is "built" into heated rear screen.  Think that estate aerial caters for both phone and radio.
Re: Elite Aerials
« Reply #3 on: 04 July 2010, 16:07:46 »
as above, Saloons get their radio signal from the rear window, Ariel is only for GSM phones.
Estate gets it radio signal from the Ariel, hence its longer  :y
    • 530D M Sport, 330i Coupe
Re: Elite Aerials
« Reply #4 on: 04 July 2010, 16:46:01 »
The stub for the phone on saloons is pretty dire tbh, it's only unity gain so when you take into account the losses in the cabling (it goes through three joins to get to the handset / head unit) it's barely better than using a built in antenna except that you've got it outside with a decent ground plane.
Even the estate aerial is flawed, while it translates to a 1/4wave colinear it loses the vast majority of it's possible 3db gain due to being at the wrong angle.
Still, could be worse, could be one of those tacky shark fins!
« Last Edit: 04 July 2010, 16:47:50 by VXL_V6 »
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Elite Aerials
« Reply #5 on: 04 July 2010, 16:46:12 »
Most common vehicle aerials are in the form of a 1/4 wave antenna, so as the frequency gets higher, ie Cell Phones, the wavelength gets shorter.
Re: Elite Aerials
« Reply #6 on: 04 July 2010, 16:49:47 »
I think one of the problems on later cars is the need to have a dual band / triple band antenna, an area where one size does not fit all!  ;D
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: Elite Aerials
« Reply #7 on: 04 July 2010, 18:03:28 »
Sat nav comes in to the elite estate by the antenna. did on mine anyway
Re: Elite Aerials
« Reply #8 on: 04 July 2010, 18:08:10 »
Thought all the sat nav was disk based.
Re: Elite Aerials
« Reply #9 on: 04 July 2010, 18:33:27 »
GPS signal is obtained by the ariel base, not the ariel itself. No data is transmitted maps are on the disc
Re: Elite Aerials
« Reply #10 on: 04 July 2010, 19:19:46 »
Ignore me I am tired, just realised the idea of sat nav is to COMMUNICATE with the sat nav, hence needing an aerial.  :-[ :-X :-/
