Author Topic: MOT Failure Update and Retest  (Read 6398 times)
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
« on: 02 May 2007, 09:26:12 »
Well, some of you may remember my MOTH failure.  Basically, car failed on Exhaust (which I expected) and a track rod balljoint and steering idler (which I did not expect).
I started work in earnest on the exhaust - got the old system off no problem but then came stuck with the centre bolts.  Managed to get two drilled out, but the other two would not drill at all.  No matter what sort of bit was used.
In the end, I gave up and drove the car (without an exhaust which was fun!) to work and gave it to the small workshop next door.  They also had a huge load of trouble and it took 3 hours for them to remove the sheared bolts!  They also did the idler arm which was also a ba****d to remove (their words not mine) requiring an air chisel apparently.
I went to the workshop feeling quite a failure, but after listening to what they had to say, I feel that I did quite well really, considering that I was laying under the car with it on axle stands!
At this point, I would like to say thanks to all those who advised me with the various issues that I had.
So, the retest is today - I went for a good hard run this morning - the new fuel filter that I fitted seems to have made a difference here.
Fingers (and everything else) crossed and wish me luck!
Bo Bo
  • Coventry
Re: MOT Failure Update and Retest
« Reply #1 on: 02 May 2007, 10:00:16 »
Good luck  :y
STMO123
« Reply #2 on: 02 May 2007, 11:25:05 »
Best of luck mate :y
ians
  • Reading
« Reply #3 on: 02 May 2007, 11:39:07 »
Good Luck mate!  Nervous time - we all know what it feels like
x25xe
  • Hayes, Middlesex
« Reply #4 on: 02 May 2007, 11:41:22 »
Thanks for the support guys - I will let you know the result later.
MOT Time - worse than a driving test!
nixoro
  • Hitchin, Herts
« Reply #5 on: 02 May 2007, 12:48:37 »
Good Luck  :y sure it will sail through now
Danny
  • Wigan, Greater Manchester
« Reply #6 on: 02 May 2007, 15:13:06 »
mine's in today for its MOT, will find out at 4 whether it passed or not
nixoro
  • Hitchin, Herts
« Reply #7 on: 02 May 2007, 15:18:36 »
Good luck for yours aswell Danny :y
Not long now :D
x25xe
  • Hayes, Middlesex
« Reply #8 on: 02 May 2007, 16:10:21 »
Good luck with yours mate.  I will find out in around ½ hours time.
Danny
« Reply #9 on: 02 May 2007, 16:59:06 »
Sadly the forum isn't big enough for me to list what mine's failed on  :'( off to the scrapper i go
i'm jokin, it passed with no advisories, as well it should, it's costin a bomb lookin after it, and thats on the cheap!!
Bo Bo
  • Coventry
« Reply #10 on: 02 May 2007, 17:49:06 »
8-) :y
x25xe
  • Hayes, Middlesex
« Reply #11 on: 02 May 2007, 18:43:13 »
I am delighted to report that mine has also passed today, with no advisories either.
At this point, I would like to say thanks again to all those who had an input to my earlier posts when I came up against it with the exhaust and the steering idler.  I managed the track rod replacement on my own though!
It was only due to this forum that I even thought of having a go myself!
« Reply #12 on: 02 May 2007, 18:48:23 »
Im pleased to hear your cars have passed :y Finger crossed theres no more problems for another 12 months ;)
STMO123
« Reply #13 on: 02 May 2007, 19:03:06 »
Well done, both of you :y
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #14 on: 02 May 2007, 21:54:40 »
well done guys  :y  :D
