Pages: 1 [2] 3  All   Go Down
Author Topic: where can i get basic engine/mechanic knowledge???  (Read 5889 times)
davethediver
  • Blackburn, Lancs.
Re: where can i get basic engine/mechanic knowledge???
« Reply #15 on: 25 September 2010, 20:24:12 »
hi guys,
i read your posts and wonder how you guys know all this info on your engines? i know nothing apart from how to check/top up oil, coolant and screen wash hhahaha ;)
i am so rubbish. how do i get sum basic knowledge so i can do basic repairs/checks???? :):):)
Take your car to bits and then try to put it back together again :y
actually agree with you on this one steve. :y
Many a true word spoken in jest! :D
Keep your miggy long enough & you'll be a fully fledged spanner strangler for sure  ;D ;D ;)
Got to agree with Phil on that one i knew very little before i got my first omega, come to think of it i still know very little and thats not just cars ;D.
But from following the guides on here asking questions and help from other members your confidence and skill level will grow (Hopefully not at the same rate as your bits left over box) :y :y
P.A. Caron de Beaumarchais
« Reply #16 on: 25 September 2010, 20:33:39 »
With all the good advice that has been given there is one more key fact;  start collecting the best tools you can afford as you need them ;) ;)
Without the correct, and quality tools, any job on the car is just that bit more difficult, and with some jobs impossible! :D :D :)
« Reply #17 on: 25 September 2010, 20:51:53 »
Quite honestly, "basic car mechanics" won't help you at all when it comes to something like an Omega V6.
So much of the modern car depends on electronics that it just isn't possible for the ordinary man in the street to do very much as he doesn't have access to £30,000 worth of diagnostic equipment.
The wizards you encounter on OOF are exceptions, and it will take many years of dedicated toil to achieve their level of expertise.
However, there is a price to pay for this!
yep.. agreed.. modern day cars are quite complicated even for experienced mechanics if they dont have a deep understanding of engine management system.. because its highly dependant on electronic sensors..
and although most service workers even using equipment like tech II (or other), after some point they go on a trial error basis ..
however basic understanding of mechanics+engine management system will at least help .. also probably you will be able to service simple items at least with some tools..
also I must note best practice is hands on job.. (and if you have an experienced person near you that will be perfect)
« Last Edit: 25 September 2010, 20:53:34 by cem_devecioglu »
whippit
  • Kirkcaldy, Fife
« Reply #18 on: 25 September 2010, 21:03:19 »
Suck, Squirt, Bang. Blow
All you need to know ;)
The rest is just nuts and bolts
Omegatoy
  • UK
« Reply #19 on: 25 September 2010, 21:10:18 »
dont you mean suck, SQUEEZE , bang , blow?
whippit
  • Kirkcaldy, Fife
« Reply #20 on: 25 September 2010, 21:14:32 »
Doh  [smiley=embarassed.gif]
Bent valve
« Reply #21 on: 25 September 2010, 21:25:58 »
The thing I find with these cars is not that they are complex, but there is bugger all room in the engine bay to get to  anything, especially if you have hands like spades as I do.
Take exhaust manifold removal for instance, you could remove one From a Cortina in 20 mins, but it would take the average home mechanic a day to get one off a V6 Omega even though they are bolted to the engine in exactly the same way as a Cortina manifold.
 In many ways Omegas are otherwise a lot easier to mantain than cars of 30 years ago in that you dont have the hassle of ignition point adjustment / timing, valve clearance adjustment, Mixture settings ect.. that had to be attended to on a regular basis, and if you think changing Omega wishbones is a pain, you have probably never tackled the kingpins on an Austin Cambridge. :P
All things considered, I reckon Omega maintenance and repair is a lot easier than you might think, especially with all the FREE expert guidance available on here :y
« Last Edit: 25 September 2010, 21:27:21 by Bent_Valve »
tidla
  • solihull
« Reply #22 on: 25 September 2010, 21:26:22 »
been watchin the wrong maintenance video i feel... #19
« Last Edit: 25 September 2010, 21:27:08 by tapper888 »
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #23 on: 25 September 2010, 21:39:31 »
Definitely agree with this! I've found that the main part of most jobs on migs is moving other bits out the way just to get access, even then it's awkward! Wouldn't wish o/s exhaust manifold gasket on anyone!
TC and BnQ Trade holder.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #24 on: 25 September 2010, 21:52:00 »
thanks for all the info guys. i went on the maintenance guide to see how i can clean my ICV (as i have an uneven tickover) but i dont really understand it :(
i agree though it wud be very satisfying to do this stuff myself :)
RIP Paul Lovejoy
« Reply #25 on: 25 September 2010, 22:18:47 »
Stick your location in your profile, you might find someone lives near you and is willing to show you the basics. You'll learn a lot faster if things are explained, in person, as work is done.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #26 on: 25 September 2010, 22:51:37 »
Apart from the other very wise bits of advice, this is one thing I always look for if using a workshop manual, (especially Arthur's) it is amazing how often five minutes taken in removing some obstruction, can save hours on the job itself. :y
jereboam
  • Suffolk
    • 1999 Omega Elite 3.0
« Reply #27 on: 26 September 2010, 00:09:52 »
Quite honestly, "basic car mechanics" won't help you at all when it comes to something like an Omega V6.  Or, for that matter, any car made in in the last 20 years.
I used to do all my maintenance and repairs 40 years ago.  Now, when I lift up the bonnet, I can't even name most of the parts I'm looking at.  A couple of years back, when the car just stopped and I had to call the AA, the bloke who came along said that if it wasn't something obvious, he didn't stand a chance of identifying the problem, and even if he could identify it, he probably wouldn't be able to fix it.
However, there is a price to pay for this!  I won't go into details, as I wish to remain a member of the forum.  :) :) :)
I used to think the same J, and had "stopped" doing any work on cars from the time I got the Granada Scorpio, in the same belief as you. That continued through to the old omega - the blue one - which developed a problem that the "dealers" said was extremely rare and would cost over £1000 to fix, "and to the complexity of the electronics this might not be the full solution". At the time I did not have £1000 to chuck at a "possible" fix, so in desperation I started to search on t'web. I found here with an exact description of the fault and the fix, and the information that it was relatively common knowledge - ABS ECU. Armed with that knowledge, and some help from forum members, the ECU was removed, sent for repair, and replaced, in less than a week, for less than £150. Since that point neither car has been to a garage except for WIM - geometry - and MOT's. I have learned, and been instructed, by forum members all the way through, or folks like Elite Pete, Daz, or Chris Gixer have done the work for me, the first time, but have taught me how to do the job should it need repeating.
I accept there are some jobs I'll probably never attempt, but I can now do one hell of a lot more than I could, and I can certainly do all the "routine" stuff without hesitation, and I'm more confident in attempting other work, knowing there is a wealth of support at the end of the phone line .. either by calling or by broadband !!  :)
There are 2 major advantages to that ..
1 . Cost
2.  I know the job has been done properly.
Just my views .. nowt else .. :)
I'm sure you are right.  The web and especially OOF are an outstandingly good resource to have available, and the wizards here are phenomenal.  But OOF is, I suspect, an exception.  Not only is the knowledge here, there is also the willingness to share it, and to physically provide the helping hand.
But it doesn't get round the fact that modern cars just aren't amenable to do-it-yourself repairs as far as the average reasonably competent handyman is concerned.
I learned quite a lot about engines when I owned a Triumph Herald, because I couldn't afford to take it to a garage.  When I traded that car in for an Austin Healy Sprite, what I'd learned about engines still applied.  I could adjust the timing, tune the carburettors, do an oil change - I even managed a full de-coke on occasion.  When I bought a Jaguar S-type, I could still do a lot of the work, but some of it required special kit which just wasn't a practical proposition.  And I have to admit that tuning the carbs on the 6 cylinder engine utterly defeated me in the end.  But at least I knew the general idea of what I was doing, even if I lacked the skill to complete it to perfection.
Today's cars require much more than the basic skills to maintain and repair.  And when a complex engine is shoe-horned into a car the way the V6 is crammed into the Omega, relatively straightforward jobs become to frightening to tackle.  For example, I recently asked on here about a problem I was having with the engine revs surging following the coil pack replacement by a garage.  I got a consensus opinion back which pointed towards the vacuum pipes entering the plenum have been put back incorrectly.  I understand the words, I can see the top ends of the pipes, but can't see where they go and I haven't got the first idea where to start if I want to fix it.  And I don't understand the problem well enough to convincingly explain it to the the garage which screwed it up or to another garage.
Never had this problem on the Herald. :)
« Reply #28 on: 26 September 2010, 00:44:35 »
Iirc, with the Herald you lifted the front forwards out of the way and then stood in the engine bay while you worked on the engine. No denying the Omega is a bit different in that respect. ;) :D
« Reply #29 on: 26 September 2010, 01:29:06 »
Indeed Albs, but in those days most cars had plenty of room to get at everything..... :y  My Citroen C4 Grande Picasso, when you lift the bonnet, under there hardly even looks like and engine and is so set back I would hate to work on it... ::) 2 months, agreed, over the lease, loathed to send it back though.... :'( :'(
« Last Edit: 26 September 2010, 01:29:33 by floodm »
Pages: 1 [2] 3  All   Go Up
