Project TB1
Started by TheBoy, 21 August 2006, 21:34:09
Its not available as the car its off has the extra coolant pump so the pipe goes from the back of the block and around to the header tank area.
Markie
so when do we get pic of Project TB1  :D
QuoteIts not available as the car its off has the extra coolant pump so the pipe goes from the back of the block and around to the header tank area.
This one has the pump as well, where cruise normally is. But still got this short pipe from HBV to coolant bridge...?
Martin_1962
Quoteso when do we get pic of Project TB1  :D
nixoro
Good luck with the Project TheBoy :)
Any chance of some piccys of the new addition.
Yeah, will try and take some piccies maybe tonight.
Mrs TheBoy took some piccies with the plenum and intake bridges removed to show a socket that the previous mechanic had left behind....
Now I understand....the pipe you need is there....in fact its already removed!
RonaldMcBurger
#22
Not only removed, but on its way to TheBoy as we speak! ;)
Cheers Ronnie, you're a diamond geezer  :D
