Author Topic: Bit shaky in Cumbria tonight?  (Read 946 times)
Nickbat
« on: 21 December 2010, 23:58:52 »
http://www.bbc.co.uk/news/uk-12056634
Any OOF members felt the earth move for them tonight?  ;)
Banjax
  • Perth
Re: Bit shaky in Cumbria tonight?
« Reply #1 on: 22 December 2010, 09:01:35 »
apparently it's devasted vast areas of cumbria - causing nearly £7 worth of damage  ;D ;D
i know an oldie but a goldie......coat, bye  ;)
markfree
« Reply #2 on: 22 December 2010, 10:34:15 »
Could say the same about perthshire...................... a few dead sheep, raspberries, strawberries etc. ;D
Banjax
  • Perth
« Reply #3 on: 22 December 2010, 12:45:48 »
funnily enough I've been passing a frozen dead sheep every morning on the way to work - legs stuck out the snow, the rest is buried........I'm thinking - how long does 200lb of mutton take to defrost?  ;D ;D ;D
smithpa7
« Reply #4 on: 22 December 2010, 12:53:36 »
What are the roads like in Perthshire. We are heading up to Kenmore on Monday ;D ;D
Banjax
  • Perth
« Reply #5 on: 22 December 2010, 13:03:35 »
all the main roads are good Zombie, so stick to the A9 and come off at the Aberfeldy junction as opposed to going through Crieff, should be OK.....unless its snows hard of course  :y
Kenmore will be beautiful by the way  ;)
edit - I'm assuming you're coming up the A1 over the Forth Road Bridge and then M90 to Perth?
« Last Edit: 22 December 2010, 13:07:31 by bannjaxx »
markfree
« Reply #6 on: 22 December 2010, 19:07:05 »
Forever, probably, as in the past 2 weeks the temperature's here haven't risen above -4.5 deg C (and thats day time temp) - all the trees around here are covered in ice, it's probably warmer in my freezer than it is outside..........even the mice have had enough as there throwing themselves (en masse) onto my traps. ;D
Banjax
  • Perth
« Reply #7 on: 23 December 2010, 07:56:30 »
 zombie - i've been using this for the roads and its been very accurate and quick to update  :y
http://trafficscotland.org/lev/
ironically the A9 north of Perth closed this morning.....like i said, stick to the mains  ;D
« Last Edit: 23 December 2010, 07:57:55 by bannjaxx »
