Author Topic: Decorating advice.....??  (Read 1502 times)
Debs.
« on: 28 December 2010, 11:32:08 »
I`m no expert with house decorating matters and have to decorate a room in another house.
The walls have been painted "Barbie Pink" :o......I think it`s emulsion painted on plaster (without lining paper); I`d probably like to go with a good quality brilliant white or magnolia replacement....how the heck can I cover such a vivid colour without using several coats and gallons of paint?
Is there such a thing as an emulsion undercoat?....if so which colour to use in Barbie`s boudoir? :-?
Welung666
Re: Decorating advice.....??
« Reply #1 on: 28 December 2010, 11:35:03 »
Go to somewhere like B&Q and get a big tub of the cheapest white emulsion they do and apply 2 or 3 coats. Then cover with a good quality one coat emulsion. We had to do this in middle daughters bedroom, her walls were a similar colour to your pic. Her room is now a subtle mushroom colour and much less painful to look at :y
« Reply #2 on: 28 December 2010, 11:35:42 »
no easy way around it, you could try Dulux's "One Coat" - But thats often just as expensive as two coats of standard brilliant white.
When I did my living room in my flat the colour change was not big, but still took 3 coats  :(
« Reply #3 on: 28 December 2010, 11:36:19 »
Personally I think you should tell Daz, to decorate his own bloody bedroom. ::) ;D ;D
« Reply #4 on: 28 December 2010, 11:36:55 »
I like this method of painting Debs.   :y
[media]
http://www.youtube.com/watch?v=T9MAmWnOznI[/media]
« Last Edit: 28 December 2010, 11:41:09 by skruntie »
  • Online Online
« Reply #5 on: 28 December 2010, 11:43:31 »
I disagree Welung. Names like Johnson's paint is far preferable to B & Q's own and covers far better with each coat thereby saving you the extra effort of painting the room half a dozen times.  ;)
Welung666
« Reply #6 on: 28 December 2010, 11:49:13 »
The difference between the 2 though, is getting 15 litres of B&Q value for the price of 5 litres of Johnson's. We did 3 coats of the B&Q then a top coat with Dulux ' One Coat'  and it covered completely.
  • Online Online
« Reply #7 on: 28 December 2010, 11:52:29 »
But .... would the Johnson's have covered the wall 3 times better than B & Q's 3 times cheaper emulsion?  ;D ;D
Welung666
« Reply #8 on: 28 December 2010, 12:12:52 »
Unlikely, maybe 2 coats :P ;)
Debs.
« Reply #9 on: 28 December 2010, 12:25:00 »
Thanks guys...... ;)
Perhaps it`s a daft question, but should I use a cream/magnolia as an undercoat for the brilliant-white; for it`s higher opacity (perhaps?). :-?
I don`t mind going Dulux or Johnsons, as long as it`s not going to take dozens of coats. ;)
« Last Edit: 28 December 2010, 12:25:18 by Debs. »
  • Online Online
« Reply #10 on: 28 December 2010, 12:30:48 »
not sure  :-/ I think I'd use white, then you're only buying the one colour/tub of emulsion
IMO you're going to need less coats with the named brands.  :y
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #11 on: 28 December 2010, 12:35:37 »
I recently used a Home Base own lable white cheap and   exellent coverage, you probably won't need a named brand as a top coat I think 2 or 3 coats will do the trick :y
hotel21
  • The Kingdom of Fife
« Reply #12 on: 28 December 2010, 12:36:27 »
Done similar in the past.  I used a spare can of magnolia or mushroom or something to take the sting out the vivid colour (it was just gash paint that was in the garage) then finished with a proprietry topcoat.   Worked out fine in a couple of coats...
« Reply #13 on: 28 December 2010, 12:37:49 »
2 coats of 1 coat imo. :y...........did that sound Irish ? ;D
Debs.
« Reply #14 on: 28 December 2010, 12:43:24 »
 :D Yes, it didn`t! ;D
Page created in 0.033 seconds with 20 queries.
