Author Topic: Why do other cars not have multi rams or dual rams  (Read 2000 times)
PxMetro
  • Stamford
  • Maryland Cookies are brilliant for dunking
    • 3.2 MV6 Estate
Re: Why do other cars not have multi rams or dual rams
« Reply #15 on: 31 December 2010, 07:13:43 »
Nice wiki find Kevin, I'd always wondered what the theory was behind the variable inlet.
Here's an interesting article on a Variable Compression 2 Stroke engine. The idea's been around for a while but has recently been picked up again by a collaboration between Lotus Engineering, Quens University Belfast, Jaguar Landrover and fuel injection specialists Orbital Corp. They are boasting fuel efficiency savings of up to 30% when compared with some of todays four stroke engines. It is also able to run on more than just one fuel type and uses "Homogenous charge-compression ignition" meaning no spark plug. I think up to now they have only been experimenting with a single cylinder, but plan to start looking a multi cylinder. One interesting fact I picked up on was that for them to meet the industry standard for cold starting without assistance of -30DegC, the engine compression ratio would need to be 50:1. I think they have managed -25DegC up to now.
http://en.wikipedia.org/wiki/Variable_compression_ratio
« Reply #16 on: 31 December 2010, 12:23:46 »
Loads of engines have variable inlet manifolds.....inlcuidng diesels!
That's interesting, I certainly didn't know that diesels did!
I take it having a variable inlet on a charged engine wouldn't be useful then?
Yep, its basicaly what the swirl flaps do on the multivalve diesel engines.
When they actually stay attached to the rod :P
Nah, fixed once and for all in 2006 with a modified inlet ;D
« Reply #17 on: 31 December 2010, 12:34:25 »
Interesting, neighbours e39 D has had swirl flaps removed and blanking plates fitted, reckons it makes no odds to remove them, they are about the area of a 1pence piece on his....absolutely appalling construction btw.
