Author Topic: Back Pain - Still not better  (Read 7086 times)
Banjax
  • Perth
Re: Back Pain - Still not better
« Reply #15 on: 14 January 2011, 11:36:30 »
i did my back in last week breaking ice on the path with a heavy 5 foot pinch bar (someones borrowed the pick i guess) - havent slipped a disc or anything but its so debilitating i totally sympathise - heat packs ibuprofen and paracetamol are keeping things tolerable at the mo, but i know how frustrating it is  :(
A bottle of single malt will do the job much better - except by the morning pain will have shifted to the head  ;D
true, although i then fall victim to UDI's :y :y
« Last Edit: 14 January 2011, 11:37:48 by bannjaxx »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #16 on: 14 January 2011, 13:02:26 »
I have been myself this morning to the Ostepath, it bloody hurts when they crack you  :-[
Need to rest it for a bit so, off to take the dog a walk  :y
« Reply #17 on: 14 January 2011, 13:57:37 »
I hope you feel much better soon LD :y :y
Back pain is one of the worst and it certainly can greatly incapacitate :'( :'( :'(
dragonlord
  • luton
« Reply #18 on: 14 January 2011, 16:52:29 »
a sliped disk /hemerated disk and faset joint snydrome are two total diffrent things and not the same
a sliped disck id a where the disk buges out and will press on the nerves in spinal cord
The bone surfaces of the facet joints are covered with a specialized tissue called articular cartilage. The joint is lined by a membrane called the synovium and enclosed in a fibrous sac called a joint capsule. A thick liquid (synovial fluid) surrounds the joint, allowing the bones to move without friction.
Facet joint syndrome refers to pain that occurs in the facet joints. This syndrome most often affects the lower back and neck. Lumbar facet syndrome might cause referred pain to the buttocks and thigh. Facet syndrome in the neck might cause headaches or shoulder pain.
did they do a MIR scan IF they dident the diagnosis from your doctor is a guess as they no way to tell without a MRI scan
xrays or prity much usless for diagnosing back pain
even any one ove 40 will have amnormalitys that show on a mri that may ot may not cause pain
sliped disk or rather the proper name a hemerated disk as they dont acturly slip
will show up as very dark/black compared with the good ones that are white on the mri
iv suffered with back problem due to scolliois all my life pain started bad when i was in my 20`s
last 2 years have been the worse then some thingy rear ended me car and cause even more back problems
back pain aint fun is it
opaites are your freind lol
normaly any work i do on the car needs a decent dose of codiene or morphine shortyly there after
worst time was when i woke up and pased out with my upper back and couldent move my arms for a week
was layed up for 3 weeks solid  went stir crazy neally
it took a whole bottel of johny walker black to and two pepole to get me from the living room to the bed
thease day just a walk around the shops most days requires me to take a minimum of a least 60mg of codiene
as i suffer cronic lumbar back pain, thoradic and cervical back pain
along with sianica and sholder and arm nerve pain
heat is good for pain take a couple of hot baths a day wheat bags are good for heating triger points
as for pain killers everyones different to whatworks best
best of luck back pain aint fun
« Last Edit: 14 January 2011, 17:12:25 by outlaw1234 »
dragonlord
  • luton
« Reply #19 on: 14 January 2011, 17:34:06 »
Its only pain, it will go away (eventually) :P
some times it dont sadly for some and you just have to live it
« Reply #20 on: 14 January 2011, 18:26:33 »
Agree totally... But seems I had/have a combination of both. The Facet Joint Syndrome was what has always caused me mild-severe discomfort in the past but the "Slipped" disk is what has highlighted it... May be more serious so further investigation to be done on Monday and we'll see where it goes from there.
Unfortunately I'm not very good at doing nothing... Having had severe knee problems from age 11-16 (when it was finally operated on) I learnt at a very early age to live with pain and get on with it, hence my very high pain threshold. Starting to go a little stir crazy being at home so much but both Company Doctor and HR department have told me to go out, visit friends/the pub and generally socialise as much as I am able. Was concerned about doing this in case the "Jungle Drums" started banging at work ::)
Finally managed a good 4-5 hours sleep last night but was medicated so not sure how I'll get on tonight.
« Reply #21 on: 14 January 2011, 18:28:09 »
Should have known you'd be sympathetic ::) ::) ;D
Might have to get Mrs LD to make me a batch of Brownies this weekend to make me feel better ;) :y
« Reply #22 on: 14 January 2011, 18:31:17 »
Good news on the work front, they could have been really nasty about it given current climate!
Get yourself an Xbox, I just started on Call of Duty Black Ops last night, before i knew it was 1AM!
I only just got up too  ::)  8-)
The good thing about working for a large, unionised company :y :y
At the end of the day, I have had more time off with this problem than I ever have (total) in the 6 years I've worked there so they're being reasonable. I don't normally take time off because I don't like to and would go back to work tomorrow if I were fit to :y
dragonlord
  • luton
« Reply #23 on: 14 January 2011, 18:35:00 »
i know what you me my hips are rotated so my hips are out of line
and get a lot of knee pain from walking and scolliosis often cause a early onset of arthoritus
what medication you ?
simular too you self i go crazy when i cant do what i want to to do
last time i poped a disk at about L5 i was so bad it was a blue light job by ambilance on gas and air
then the morons at local hospital dignosed a sliped disk as kiddy stones
and wouldent lisen to me and get some from ortopidics up so i ended up checking my self out
of course it was a disk and not kiddy stones
as for work screw that m8 take it easy dont make worse
it best to not rest top long and move aroung a bit gently if you can but dont rush back to work ity not worth it m8
« Last Edit: 14 January 2011, 18:39:58 by outlaw1234 »
« Reply #24 on: 14 January 2011, 18:39:31 »
Currently on Arthrotec (which is Diclofenac and something) as anti-inflammatory because Ibuprofen has little effect on me after taking it in a very large dose for 5 years. And Co-codamol for the pain, although I try not to take the pain killers if I can help it as it hurts for a reason and I'd rather know it hurts than mask it and make it worse ::)
Although last night it was something a little stronger I took which was lurking in the medicine cupboard :-X ::)
dragonlord
  • luton
« Reply #25 on: 14 January 2011, 18:46:33 »
yea im on 30/500 co codamol and instaint morphine when its really bad
nsaid/ aintinflamitrys do naff all for pain just mess my stomack up
they tryed amatriplin for nurve pain but that stuff zombified me
and tramadol just got me high and done nothing for pain
the other stuff in the Arthrotec is for the stomack to protect it from the declofenic giveing you and oulcer
« Last Edit: 14 January 2011, 18:50:25 by outlaw1234 »
Richie London
  • heathrow
« Reply #26 on: 14 January 2011, 18:57:29 »
i have to take those 2 as well as others, i treble up if the pain reaches its worse, get so out of my head i forget ive got a back ache. ;) i am still waiting to see the surgeon 8 months after i was told i need this treatment done. my hospital is totally crap.
i have every sympathy for anyone with back problems, the 2nd most painful thing ive ever suffered with
dragonlord
  • luton
« Reply #27 on: 14 January 2011, 19:15:19 »
i wont have an op done as they cant garantee pain relife
and i dont fance having my spin fused from my ass to my neck
Richie  untill you had back problem you cant imagin what its like as you know
iv had some shit doctors lucky my current gp suffers with back pain so got a intrest in it and know what hes on about pain wise
« Last Edit: 14 January 2011, 19:17:49 by outlaw1234 »
Richie London
  • heathrow
« Reply #28 on: 14 January 2011, 19:37:10 »
i'm waiting for botox inj to the discs so presume its expensive. but its the point that i cant get an appt that pisses me off, keep being told there full up and unable to give me a date.
waspy
« Reply #29 on: 14 January 2011, 19:50:13 »
No consolation, but many of us know how it feels & it's bloody annoying, because of what you can't do. Neck & back are the worse injuries to have.
Get well soon Paul :y :y :y :y
