Author Topic: would this be easy to do.....  (Read 2933 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 25 January 2011, 22:43:39 »
...... found this omega on autotrader (im really sad and look at this stuff all the time lol)
http://www.autotrader.co.uk/classified/advert/201102377341105/sort/priceasc/usedcars/model/omega/make/vauxhall/postcode/nn37bl/page/2/quicksearch/true/radius/1501?logcode=p
bearing in mind i know nothing about mechanics, pure interest id like to know if the things that need doing wud be easy to fix??????
 :y :y :y :y
RIP Paul Lovejoy
Re: would this be easy to do.....
« Reply #1 on: 25 January 2011, 22:47:26 »
Not major work TBH, although if you have little mechanical experience the brakes may be better tackled by someone more expert ;)
This may well belong to someone on here... Sure I read a question somewhere about the in tank pump :-/ :-/ May, of course, just be a coincidence :y :y
« Reply #2 on: 25 January 2011, 22:51:41 »
Worth a punt. If (and it`s a big if) fuel pump is playing up (£20 S/H) it wouldn`t lack power. Could be one of many things, not necessarily expensive. If it`s close enough to you why not have a looksee and try the pedal trick for codes.
Webby the Bear
  • Northampton
« Reply #3 on: 25 January 2011, 22:52:28 »
hmmmm very roughly speaking how much wud it cost (if those were the only faults) to buy it, take it to a garage and have the work done? 8-) 8-) 8-)
RIP Paul Lovejoy
« Reply #4 on: 25 January 2011, 22:53:07 »
Very true... More likely that the fuel filter hasn't been changed ::)
Webby the Bear
  • Northampton
« Reply #5 on: 25 January 2011, 22:53:57 »
pedal trick for codes????? lol
RIP Paul Lovejoy
« Reply #6 on: 25 January 2011, 22:55:36 »
Front discs & pads about £100 trade, easy DIY job. Rears, probably pads only, about £12. Fuel pump, if needed, I got one here secondhand £20. 15 minute job under the boot carpet
« Reply #7 on: 25 January 2011, 22:56:54 »
Print this off & take it with you http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
tidla
  • solihull
« Reply #8 on: 25 January 2011, 23:01:11 »
no mention of history and looking at the mileage its due a big spend..
also the tax on the later 2001 models is an eye watering amount.
if your paying someone...could well add up.
« Reply #9 on: 25 January 2011, 23:03:27 »
also the tax on the later 2001 models is an eye watering amount. ...
No it's not. Can't remember the details but you're confusing mega road tax with Mar 2006 onwards.  :y
« Reply #10 on: 25 January 2011, 23:07:50 »
That looks a tidy car, for that money got to be worth a look.... :y I recently bought, on paper and presentation, a first class car, in August, have spent £1100 on it since and only a 2.2...... :'( :'( :'(
If viewing was OK I would buy it if near to me.... :y
tidla
  • solihull
« Reply #11 on: 25 January 2011, 23:11:41 »
sneaky if not (avoiding the exercise) k band :y
http://www.direct.gov.uk/en/Motoring/OwningAVehicle/HowToTaxYourVehicle/DG_10012524
glad im not buying a brand new omega at todays robin hood tax charges :o
« Last Edit: 25 January 2011, 23:14:16 by tapper888 »
Webby the Bear
  • Northampton
« Reply #12 on: 25 January 2011, 23:18:09 »
thanks robg for those code details/paperclip test etc :):)
my spark plug leads have just been replaced and the cars still not running quite right.... cud i do this to see if theres anything else up?
also silly question but does the fuse box cover.... does it come off easy/easily accessable???
cheers. :y :y :y :y
RIP Paul Lovejoy
« Reply #13 on: 25 January 2011, 23:21:09 »
Yours uses a paperclip. Fusebox by battery just unclips (if that`s the one you mean)
Webby the Bear
  • Northampton
« Reply #14 on: 25 January 2011, 23:23:05 »
under the steering wheel, right?
will give me something to do over tut weekend  ;D ;D ;D
do i put it the paperclip in the same holes ( ;D ;D murhahaha) as in the photo you forwarded?
RIP Paul Lovejoy
Page created in 0.024 seconds with 20 queries.
