Pages: 1 [2] 3  All   Go Down
Author Topic: Cutting my project car into little pieces  (Read 14808 times)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Cutting my project car into little pieces
« Reply #15 on: 22 August 2006, 14:59:09 »
 ;D ;D ;D ;D
May come to that as the wife aint keen on the tool hire type plan - she reckons i am dangerous!!
« Last Edit: 22 August 2006, 14:59:24 by Markiec »
Liam
« Reply #16 on: 22 August 2006, 16:18:56 »
The potential problem i can see with a plasma cutter is thick beams and folded seams that you'd have to be able to get all the way around with the torch.  I've cut up both a car and a transit van with one of these...  (I used a 12" version but a 14" would be even better for deep sections).  Proper man's tool too!  Also - Speedy Hire are loads cheaper than HSS.
http://www.speedyhire.co.uk/technical_catalogue.aspx?id=1143&fSize=smaller&fImages=1&nav=|0|0|0|0|0|1144|1141|4668|4669|1142|1143|1145|2557|0|0|0|0|0|0|0|0
Liam
« Reply #17 on: 22 August 2006, 16:26:35 »
yeehaa that looks the buisness and there one of the branches about half a mile from me
Cheques in the post Mark  ;)
Try the other local hire shops to as HSS can be pricey.
Markie
« Reply #18 on: 22 August 2006, 16:37:38 »
Will suss it out guys - i reckon these things will be noisy as well wont they  :(
« Reply #19 on: 22 August 2006, 16:39:23 »
Plasma cutters arn't, they are much quiter than angle grinders plus the metal is pretty much cold so much safer
Fantastic bits of kit.
« Reply #20 on: 22 August 2006, 16:42:07 »
« Last Edit: 22 August 2006, 16:43:21 by Mark »
« Reply #21 on: 22 August 2006, 16:54:54 »
....... and my personal favourite............ a very sharp cold chisel and a big hammer!
Now .... there's surprise!  ;D  ::)
nigsey1600e
  • leicsester
« Reply #22 on: 22 August 2006, 19:46:27 »
As a sheetmetal worker/welder/plater myself cutting up your rover would be a piece of cake. at least you wolud be able to do it with a normal  4.5 inch angle griner and thin cutting discs and or even a oxy acteleyene kit   or even better a plamsa all  this  kit ou could hire for a very reasonable price and would only take about 5 hoursish if you were nearer i would do it for fun ;D
MartinP
  • Dudley
    • BMW 320D
« Reply #23 on: 22 August 2006, 22:29:46 »
I did this
with one of these ( with the appropriate disc on)
in 2,  3 hour sessions  (on my own)
sorry about the fucus  :-[  ( its not a spellinig mistake)
Markie
« Reply #24 on: 22 August 2006, 22:57:11 »
so it most definatly CAN be done!!
Issanaz
whats that tool in your picture ?
Nigsey thanks for you rfeedback as someone in the line of work.....appreciate it!!
MartinP
  • Dudley
    • BMW 320D
« Reply #25 on: 22 August 2006, 23:06:05 »
we call it a "slab cutter", it a 2 stroke petrol unit that takes 12" concrete,or metal cutting discs, I used 2 discs and took them down about 2 inches.
I had the benefit of an "A" frame to turn the shell over.  But it was a fun weekend  :)
Google "slab cutter"
nixoro
  • Hitchin, Herts
« Reply #26 on: 23 August 2006, 09:24:08 »
I'm sure I have seen the fire services use something similar.
Issunaz you certainly made short work of breaking that one up.  ;D
nigsey1600e
  • leicsester
« Reply #27 on: 23 August 2006, 17:15:16 »
Issanaz
not a problem allways keen to try and help ;)
« Reply #28 on: 23 August 2006, 17:17:34 »
Its a stihl saw........which is a petrol powered large angle grinder...
MartinP
  • Dudley
    • BMW 320D
« Reply #29 on: 23 August 2006, 18:28:32 »
I knew that  ;)
Thought there may be other makes in that part of the country  :D
Pages: 1 [2] 3  All   Go Up
