Author Topic: when did you last hoover out your PC tower?  (Read 1882 times)
« on: 19 July 2011, 21:15:50 »
stick with it to the end, page 9 onwards are the best  ;D ;D ;D
http://www.theregister.co.uk/2010/11/26/ventblockers_2/
Plomien
  • Swansea
    • Landrover Freelander TD4
Re: when did you last hoover out your PC tower?
« Reply #1 on: 19 July 2011, 21:32:56 »
I have seen some muck in PCs, worst is definitely from a smokers house where the tar builds up on the components.
Not found any creepy crawleys so far
« Reply #2 on: 19 July 2011, 22:09:06 »
Found some stuff in them over the years.
Hoovered out one about 3hrs ago ::)
« Reply #3 on: 19 July 2011, 22:10:53 »
you know what I mean. Not everyone has a compressor in their garage.  :y
« Reply #4 on: 19 July 2011, 22:11:50 »
When I say hoovered, I actually meant took it outside and used a compressor ::)
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #5 on: 19 July 2011, 22:13:32 »
Don't think I'll bother now  :(
« Reply #6 on: 19 July 2011, 22:22:18 »
I Dyson mine ::)
« Reply #7 on: 19 July 2011, 22:31:03 »
I Dyson mine ::)
That's cos you're all posh in Cheshire.  ::) ::) ;)
« Reply #8 on: 19 July 2011, 22:39:23 »
those pc's can easily start fire in home..
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #9 on: 20 July 2011, 00:03:42 »
Only last week. It was every bit as full if not more of dust. Even took the power supply to bits and was surprised to find a fan in there.  Spain really is the dustiest place in the world. :y (Not many bugs though)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #10 on: 20 July 2011, 00:06:56 »
When did you clean out your lappy's heat exchanger? It's amazing the amount of fluff that builds up on them, usually only noticed when it starts to overheat and shut down "for no reason".
TuBy's new whipping boy.
« Reply #11 on: 20 July 2011, 00:14:29 »
My lappy has been shutting down for no reason since I got it, usually after its been running for quite a while. Presumably overheating. Its a refurb jobby, so maybe someone forgot to hoover it out during the refurb. :-/
« Last Edit: 20 July 2011, 00:15:37 by albitz »
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #12 on: 20 July 2011, 00:23:49 »
You'll probably find a carpet of fluff wrapped around the heat exchanger Albs.
I usually take the heatsink/fan assembly out and attack it with the compressor then renew the heat sink compound when I put it back.
« Reply #13 on: 20 July 2011, 00:25:00 »
Nope, sorry - youve lost me. :-[ ::) ;D ;D
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #14 on: 20 July 2011, 00:31:34 »
Some like this acer are a piece of cake, take off the memory/cpu cover and unscrew the heat sink unit. Did a tosh the other month that needed virtually stripping to the motherboard to get the fan out. It depends how it's been designed. If you want to try it have a google around for a service manual for your lappy, that should give you a clue how it comes to bits.
Page created in 0.038 seconds with 20 queries.
