Pages: 1 [2] 3  All   Go Down
Author Topic: Electric shower on the blink  (Read 3355 times)
redelitev6
Re: Electric shower on the blink
« Reply #15 on: 07 August 2011, 19:31:14 »
Might be worth looking at wickes for a shower, ours is a triton with wickes logo, new shower fitted exactly in the old ones place, saved a load of hassle  :y
« Reply #16 on: 07 August 2011, 19:35:42 »
Saving hassle is exactly what I want!  :y :y I look at Wickes too!  ;)
Martian
« Reply #17 on: 08 August 2011, 15:08:02 »
I'm curious as to why it's got hot in the first place though.  :-/
PCB build went to the cheapest bidder, and they were more than likely the cheapest because they use components that are right on the edge of their maximum rating when in use.
The resistor doesn't look burnt out, but you can tell it has certainly been getting warm in use which will eventually lead to premature failure.
I'd check the resistor (out of circuit) to see if it has strayed from what it's meant to be rated at for resistance.
I'm struggling to make out the second (and third) colour bands in that pic, but if it is red, red, black then the value of that resistor should be 22[ch937] with a tolerance of ± 5%
If the colour bands are red, red, brown then the value should be 220[ch937] with a tolerance of ± 5%
Looking at the physical size of the resistor, I'd say it's rated at a maximum of ½ watt, so go for the next size up (1 watt) when replacing.
« Reply #18 on: 08 August 2011, 15:18:38 »
It looks more like Orange/Red/Brown to me, Martian (320Ohm).. but in case we're both wrong and they're some other colours: http://www.dannyg.com/examples/res2/resistor.htm
« Reply #19 on: 08 August 2011, 15:30:25 »
I agree the resistor looks hot but not yet self-destructed.
Obvious first: Is the push switch under the "stop" button still working?
What are the solder joints on the reverse of the board like? As said, we're talking cheap as possible construction here so they might not have done a great job of building it.
Refreshing each of the joints with a soldering iron and solder would be a good start, and swap one of the non-critical push button switches with the Stop button perhaps?
« Reply #20 on: 08 August 2011, 20:47:32 »
Just had another look at this. When either hot water settings are selected a relay makes inside, when STOP is pushed the relays open as they should, but the water continues to flow. Just remove the STOP button from the board &both contacts close when the push button is pushed. It looks like I'll get another shower, I've had my money out of it.  ;) ;) ;)
All soldered joints look good.  :y :y
« Last Edit: 08 August 2011, 20:48:20 by Andy_B »
  • Auckland
    • Mazda MPV
« Reply #21 on: 08 August 2011, 20:59:15 »
When you press 'stop' and the relays open does the water run cold?
It sounds as though the solonoid valve is sticking open. I suspect the electrics & electronics are still working perfectly despite the cosmetic effects of running hot  :-/
« Reply #22 on: 08 August 2011, 21:06:40 »
Just had one last for tonight. Yes the water runs cold again after STOP has been pressed but I noticed that if I tapped the black 24VDC relay then the water stopped as it should. And then a proper look revealed the charring around the green cap?
I'll leave it tonight though
« Reply #23 on: 08 August 2011, 21:09:16 »
I think the magic smoke might have come out of that one..  ;D
This may work for a quick repair: http://sjpdesigns.com/poa/lucas.html
« Reply #24 on: 08 August 2011, 21:17:46 »
Do you think Lucas smoke replacement will worrk in a Siemens system  ::) ::)  ;D ;D
« Reply #25 on: 08 August 2011, 21:19:05 »
That reminds me, I think ours is pushing it's luck! thermostat does not seem to be working too well on the high setting, will not cool down, I was blaming the ambient water temperature, but not so sure..... :-/ :-/ :-/  I tend to use the low power setting and seems OK, but given what has been said I think I will change it as it is about 8 or 9 years old.....
« Reply #26 on: 08 August 2011, 21:21:13 »
Good point.. there could be some kind of incident resulting from that, or it might work OK for a few years and then blow up twice as bad when the shower makes a bid to take over the rest of the bathroom ;)
« Reply #27 on: 08 August 2011, 22:49:01 »
I reckon the burning around that cap is another resistor running a bit hot.
Strikes me.. If you can get it to stop by tapping the relay, the relay is probably sticking on. What's the betting that relay switches the supply to the solenoid valve?
Richie London
  • heathrow
« Reply #28 on: 08 August 2011, 22:53:35 »
i can get you a nice new one for £20 if your interested  ;)
« Reply #29 on: 08 August 2011, 22:54:14 »
Probably.
I'll have a quick look see tomorrow after work but I think that early suggestions to replace the whole thing are looking likely. Triton's spares seem bloody expensive, the main pcb is £66  :-? :-?
Looks like I'll be putting my name down for a bit of OT this coming week end to help pay for it.  :(
Pages: 1 [2] 3  All   Go Up
