WHOS IS THIS THEN?
Started by MikeDundee, 03 June 2007, 21:38:41
Jay w
yep, that's a viper kit alright.
Basically a cone filter encased in a carbon fibre housing so as to stop it from being affected by the heat from the engine bay, the cold air feed aiding this job by getting air that is outside of the engine bay.
A lot of money but worth it just for the issues its resolves
I had one on a Mk2 cav Convertible with a C2.5XE fitted, along with 3.0 cams, modded throttle body, tubular manifold and a 4 bar FPR it was kicking out 202bhp, you should have seen peoples faces when that thing took off
Big Steve
Sorry i missed you guy's at the show, probably up the drag strip watching the corsa boys trying to
hit 60mph in first gear ;D
Yes it is mine & the intake may not be to everybody's taste but its grown on me. I was going to change it but was unable to find anything that didnt restrict airflow too much.
As for the positioning it was the only place the pipe would fit and ive never had any problems with sucking up water as i tend to avoid rivers  :y
i did have to put some mesh inside as i didnt want to suck the odd furry animal.
IT'S AN OMEGA JIM BUT NOT AS WE KNOW IT
