Author Topic: Lidl Cross Cut Mitre Saw  (Read 1604 times)
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« on: 22 August 2011, 17:04:16 »
I bought this cross cut mitre saw from Lidl today and I'm impressed. It is a lot of saw for the money.  :y :y :y
http://www.lidl.co.uk/cps/rde/xchg//SID-41B5819F-7EF41914/lidl_uk/hs.xsl/index_23502.htm?offerdate=&idcheck=true&ar2=&id=737&country=GB&zipcode=GU17+9AF&city=Camberley&district=Blackwater&street=London+Road&ar=2&nf=True
More heavy duty and much better than the cross cut saw it replaces, which it is broken with tooth missing on the electric motor gearbox spline.
Re: Lidl Cross Cut Mitre Saw
« Reply #1 on: 22 August 2011, 17:09:56 »
Ooh.. I really shouldn't, but I might have to stop in on the way home..
Only thing is, I know I'll end up picking up one of everything they have like the time I went for the compressor  ;D
Richie London
  • heathrow
« Reply #2 on: 22 August 2011, 17:27:55 »
that looks a good saw for the money. i have a makita and a proline saw, i changed the blades with ones for cutting stainless steel as they give a very smooth cut on all types of timber, perfect for joints.
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« Reply #3 on: 22 August 2011, 17:35:24 »
And it's the same shade of green as a Bosch!
Seriously though, the standard issue Chinese mitre saws aren't too bad as long as you don't expect them to stand up to heavy use.  The biggest issue is unwanted flexing, so give it a wiggle and check that it is fairly rigid.
It's also worth spending a few minutes adjusting the stops so that the basic angles are correct.  Just cut a test piece and check for square in both directions, then adjust accordingly.  Ditto 45 degrees on the compound.
And don't forget, always allow room for somebody else's hand between your hand and the blade  8-)
I feel like a military academy. Bits of me keep passing out.
« Reply #4 on: 22 August 2011, 18:55:40 »
Went and had a look at these tonight .. didn't buy the saw in the end (I don't really need one) and they didn't have the shelving unit I wanted :(
Came out with some bananas and dishwasher tablets  ;D
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #5 on: 22 August 2011, 19:00:59 »
Doubt they'll have the same cutting power. ;D
TuBy's new whipping boy.
Dodger
  • Here in the sunny south!
  • I taught I saw a puddytat!!
« Reply #6 on: 22 August 2011, 20:24:24 »
Probably won't cut decent mitres either.... :D :D :D :D :D
« Last Edit: 22 August 2011, 20:24:50 by Dodger »
I always knew I'd inherit an estate, but I never thought this would be it!
« Reply #7 on: 22 August 2011, 20:27:21 »
 ;D ;D
Page created in 0.041 seconds with 20 queries.
