How many Omegas have you owned?
Started by Martin_1962, 24 August 2006, 13:36:01
nixoro
Just waiting for ronnie to post up now.  :)
Martin_1962
I've had 3 first 1 was a 2.0 Gls low spec but lasted me 195,000 miles which i think was very good i'm now on my 3rd and lovin every min ;D i pressed 5 because i've had 2 but got rid of them quick lol
Auto Addict
Now, if you asked me 'How many Vauxhalls have you owned'?.....
Or 'When did you first own a Vauxhall'?.......
No contest.....
I like red cars
Taxi_Driver
QuoteA mere intermediate for me :(
But I do get to drive loads, everytime somebody needs a Tech2 connected :D
Just a beginner me  :(
Wish you lived closer to me Jaime....id be interested to see if your Tech2 can diagnose
a) the lpg fault on my veccyC
b) why the headlights wont turn off unless you turn the ign off
Robin Hood
Can I count a 2.6 Carlton CDx as an Omega (A)?  ;)
Its a good bit of kit, used it to enable Cruise on mine  :)
nixoro
I can second that having had my car put on it, sorted my ABS issue granted it was relay related but its good as you could see what speed sensor was doing what when it was took for a run :)
Tech2 does make you lazy though - for instance, yesterday when Tunnie and I put the project car back together, the EML came on. Rather than retrace and double check all connections, a quick Tech2 showed it was 'Air Intake Valve 1 Low Voltage' which led us straight to rear multiram not being plugged in...
nixoro
QuoteTech2 does make you lazy though - for instance, yesterday when Tunnie and I put the project car back together, the EML came on. Rather than retrace and double check all connections, a quick Tech2 showed it was 'Air Intake Valve 1 Low Voltage' which led us straight to rear multiram not being plugged in...
Yeah but it makes life simpler if you have the gadgets, just think of the time saved.
Big Rod
QuoteBefore that, I had two Senators. Can I count those? :)
Before my first Omega, I had three Senators and five Carltons, (one of which I still have and it's slowly disolving in my back yard!!) all in three years.
Can I count them!
If I have to explain you won't understand!
Taxi_Driver
Bit like a Taxi Driver having sat nav.....i used to be able to remember a lot more street names than I can now, think my brain is getting lazy  :(
Auto Addict
No....you're just getting older TD.... ;D
I like red cars
Martin_1962
Taxi_Driver
But not as old as you AA  ;D
