Pages: 1 2 3 4 5 6 [7] 8 9 10   Go Down
Author Topic: Newent 2010 Jobs List  (Read 30417 times)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Newent 2010 Jobs List
« Reply #90 on: 29 August 2010, 22:40:32 »
I could give G a lift with the springs and shocks if it will free you for other jobs Mark.
Can you do AA's cambelt?
Or at least strip down and re-assemble and I will do the belt fitting?
As long as he wears clean rubber gloves......
Like sucking a toffee with the wrapper still on. ;D ;D
TuBy's new whipping boy.
hotel21
  • The Kingdom of Fife
« Reply #91 on: 29 August 2010, 22:58:41 »
As already said, happy to do pads/discs as well as learning more t2 as and when.
« Reply #92 on: 29 August 2010, 23:07:02 »
As already said, happy to do pads/discs as  .....
I'm sure Chris will let you use a bit of his new tin of copper slip ..........  ::)  ::)  ::)  :y
    • 530D M Sport, 330i Coupe
« Reply #93 on: 30 August 2010, 20:31:44 »
Happy to help where I can.  :y
« Reply #94 on: 30 August 2010, 21:23:39 »
Front Suspension/Steering check - Entwood (1 hour)
AC check - Andy B (1 hour)
Rear Bushes, springs and shocks - Gaffers (2 hours)
     Marks DTM
Wishbone check + tech 2 - Sethsmate (1 hour)
     Tech2 - Jimbob
AC check - CaptainZ (1 hour)
Frontwheel bearing, cambelt, O2 sensor, front and rear pads - AA (4.5 hours)
     Front and rear pads - Broocie, Cambelt - Captian Z, Wheel bearing - Marks DTM, O2 sensor -Kevin Wood
Rear bushes x 2 + Tech 2 check - Jimbob (3 hours) -
     Marks DTM, Tech2 - Jimbob
Front wishbones, droplinks and rear bushes - Broocie (3 hours)
     Wishbones and droplinks - Looknee (Friday), rear bushes - Marks DTM
Oil cooler re-seal - JohnM (3 hours)
     LooKnee
Sump drop - JoshWyatt (2 hours)
     VXLV6
Door lock solenoid - Bob Dent (1 hour)
     VXLV6
Tech 2 check - Astroblaster (0.5 hours)
Steering check + Tech 2 - NeilMV6 (1 hour) (Make sure you bring your security pass)
     Tech2 - Jimbob
Cambelt + water pump plus Tech 2 - MartinP (1.5 hours)
     Tech2 - Jimbob, Cambelt - LooKnee
Optional
Exhaust manifold gasket - dad1uk (3 hours)
« Last Edit: 30 August 2010, 21:41:49 by Mark »
« Reply #95 on: 30 August 2010, 21:39:09 »
I can do the door lock solenoid on Bob's car and possibly drop the sump on Josh's if required.
Who's bringing tools etc? I'm a bit stuck for space for axle stands etc but Jane will be coming down either late friday or sat afternoon so can bring some axle stands / trolley jack etc.
« Last Edit: 30 August 2010, 21:53:19 by VXL_V6 »
« Reply #96 on: 30 August 2010, 21:43:25 »
We have a few jacks and axle stands coming plus loads of tools so should be ok for that.
I will be putting up a tool list tomorrow to.
Thanks for volunteering to do the jobs, I have modified my list  :y
joshwyatt
  • Oxford
« Reply #97 on: 30 August 2010, 21:50:52 »
I'll do anything to help out, whether that be simple bits here and there, or passing tools around etc.
Unfortunately I don't really have many technical skills to offer. But I'll bring all the chemicals I use when cleaning the vehicle I have in stock, so if there are any scratches, or cleaning that's needed I'll happily do that. Even if it's leave your vehicle with me for 45 mins, and I'll tidy it up a bit.
Thanks Andy to offering to help with my sump removal, but it's not critical...I only wanted to do it to clean/check the oil pick up feed and give it a general going over...so if there's not time, that's not a problem.
My vehicle will be pretty empty so if anyone doesn't have enough space for tools, I can always pick them up.
« Reply #98 on: 30 August 2010, 21:51:02 »
I should add that to check the oil pickup, the sump drop should not take as long as I have stated.....its only the lower pan to remove
« Reply #99 on: 30 August 2010, 21:56:17 »
Presumably there's a gasket to replace on reassembly?
Will also need oil and oil filter (paper type I should imagine on a 2.6) as will be dropping the oil anyway!
PS. Josh there's some light scratches on the bonnet and boot of the DTi Elite if you want to have a go at them!!!  ::) :)
« Last Edit: 30 August 2010, 21:58:39 by VXL_V6 »
« Reply #100 on: 30 August 2010, 22:05:25 »
Almost ..... it's grey & comes in a tube  :y
« Reply #101 on: 30 August 2010, 22:06:37 »
Ah! Should be done in an INSTANT then!
joshwyatt
  • Oxford
« Reply #102 on: 30 August 2010, 22:08:07 »
That's something I'm not sure about Andy. I seem to recall reading recently that there is a gasket, but it doesn't need to be replaced, instead grey sealent is used to on re-fitting of the sump, and just grey sealant is used to fill the space.
Got plenty of oil, and oil filters.
And yep, we'll see what we can do with those scratches  :y
EDIT: Oops too slow, thanks Andy B for confirming. How much grey sealant do I need? One tube or more?
« Last Edit: 30 August 2010, 22:10:03 by joshwyatt »
« Reply #103 on: 30 August 2010, 22:16:21 »
....How much grey sealant do I need? One tube or more?
One tube would do a dozen sump pans, it comes in a tube like bathroom silcone sealent, but about 1/3 as big. I only used a small percentage of the tube when I refitted my sump pan, and threw the hardened remants away recently  :y  :y
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #104 on: 30 August 2010, 22:37:34 »
You've forgotten TB's MV6.....
I like red cars
Pages: 1 2 3 4 5 6 [7] 8 9 10   Go Up
