Oxford meet no.5
Started by joshwyatt, 14 January 2011, 15:15:11
QuoteIf I can make it, will it be too much if I turn up in British  Rail ;D ;D, seen as mig is poorly, and I can speak to jw about the likelyhood getting me a new ride.
How are you getting from Oxford train station to the venue? I ain't walking distance.
Technically, Abingdon is probably closer ;D
QuoteNo point asking me - I can't do bodywork, as will be plainly obvious if I bring the Rusty Silver Bullet  :-[
:-X :-X ::) ::) :D :D
zirk
Ok, probably being lazy now, but dont knpw the area,  can someone confirm the meet post code or something so I can satnav it on the way back from Sussex.
ChrIs. :y
Kai
QuoteOk, probably being lazy now, but dont knpw the area,  can someone confirm the meet post code or something so I can satnav it on the way back from Sussex.
ChrIs. :y
The post code is OX4 4Xp  acording to google at least, ;-)
Kai
Guess I just couldn't stay away for the fourth time....
zirk
If you're not been sorted, Im probably going to pass Abington on the way back from Sussex, but Im going to be a bit loose on times, reckon about 1 to 1:30 ish, if it helps pm your Mob No. and if I can help help, then!!
Chris.
zirk
ChrIs. :y
Kai
Thank You.  ;)
Those coming up A34, I'm sure Kassam Stadium is signposted. Basically, first Oxford turn.  Same if you're coming South, sure its signposted, its the 2nd turn past the Botley Interchange (1st being the small garden centre).
In all cases, basically follow the signs to Cowley until you get to the Sainsbury roundabout (about 1m (2nd roundabout) from A34), then you're only about half a mile away
joff
I will be starting off in about an hour so see you all there about 1pm :y
Yup, just contemplating having a coffee, lobbing some bits in the boot, then settign off in about an hour :y
joff
Good afternoon was had nice to see you all again, When is the next one Josh :y
Now back at work for a long night :'( :'( :'( :'( :'( :'(
T'was a bit nippy though, roll on nice weather ;D
ianu
..did turn a bit chilly didn't it - nice to see you all again.
I'll post the pic's up a bit later today - for those that couldn't make it - see if you can spot the Omega wannabe.... ;)
Cheers
Ian
Thanks ianu, not many meets can boast their own photographer, with proper camera.  :y
Good chat, good all day breakfast, good beer, good curry! Even managed two chutney trays.   :y
Look forward to pics. :y
QuoteThanks ianu, not many meets can boast their own photographer, with proper camera.  :y
Fatty! :P :P :D :D
Fatty! :P :P :D :D
;D Between 4 ya nutter  ;D.       :y
