essex meet ?
Started by goldwinger59, 06 November 2010, 20:59:35
Quote...1) I thought I had broken my LPG already, didn't dare ring the cripple, as I knew he'd be cross!
2) I wanted to join in the fun anyway, but Mrs TheBoy said "No" in that certain tone
3) Somebody earlier mentioned that the pedal was analogue, so I was proving to myself that it didn't need to be fully depressed. After the M1 roadworks, realised my previous method was far better ::)
1) And... Had you? :-?
2) I understand that ::)
3)  ;D ;D ;D ;D
3)  ;D ;D ;D ;D
1) Errr, well, uhmmm, it goes like this....   ....how can I put it, errrr
2) I think most of us know the different between "no" and "no" in that certain tone.
3) Then boredom struck...  ...even with 160m on trip since I reset it, no lag on high rpm changes. :y
QuoteMrs LD has requested I post the following text too:
Many thanks to all OOFers and OOFettes for a fab day!
H says, " good time had by all"  :y
And was researching micro pigs as soon as we got in. Wtf ?  :-?   :-/.       ;D
Now....  Brownies and tea.  :-*.    :y
3)  ;D ;D ;D ;D
So... Reading number 3 I assume all is well then and you hadn't broken it already?
I may have suffered similar ::) ::) ::)
Off to bed for me :y :y :y
I mentioned having a bacon butty when I got in, is that the same thing?
3)  ;D ;D ;D ;D
I think the new firmware has some funky things that overloaded my simple brain...  ...did you leave the autolearning thing enabled?
3)  ;D ;D ;D ;D
I think so... I intended to as that should fine tune it all nicely :y
QuoteI think so... I intended to as that should fine tune it all nicely :y
I wonder if that has a side effect of a brief period of petrol running every few miles?
May well do... Download AC 7.whatever it is and disable it after another day or so... That should give a good time for it to learn :y Don't touch anything else though! ::) ;D
Other thing it may be is the over-pressure relief thing but we'll check one at a time ;)
tempted to just leave it alone until certification ::)
You're still planning to get it done this week? If so, yeah... May as well :y
QuoteYou're still planning to get it done this week? If so, yeah... May as well :y
Nah, not this week...  ...maybe next ::)
Unless it starts using too much petrol it may be best for you to leave alone then ::) ;D
Also, mustn't forget my manners, Thanks to JCB for organizing, Albs for the bits, and Sandune for the plenum caps. :y
...oh....and the Stroppy Landlord at the shoulder of mutton, as we found a much better location.  :y
