Author Topic: Towbar recommendations for a facelift MV6  (Read 2942 times)
kev h
  • Nottingham
« on: 07 June 2009, 22:33:37 »
Hi all, I have just become the owner of a caravan after a very wet weekend camping! Any info or advice on a good towbar for a 2000 MV6 would be appreciated. Been looking at the new towbars with invisible mountings - anyone got one fitted, and can anyone recommend anywhere to get one fitted in the Nottm \ Derby area.
thanks, Kev,
You tried your best and you failed miserably. The lesson is, never try.
Re: Towbar recommendations for a facelift MV6
« Reply #1 on: 08 June 2009, 12:00:28 »
got mine in the for sale section on here. They come up quite often as far as i can see. Couple of types for the saloon. Mine has a flat plate bolted to the boot floor under the carpet. No good for fitting a large lpg tank behind the rear seats as you need a flat floor, my tank is in the spare wheel well so thats ok. It also has a swan neck which can be unbolted if needs be. But is also cheaper than a removable item. Did have to trim the bumper a bit though.
If you need the boot floor flat then there is a type that has a bar under the fuel tank. Hth
« Reply #2 on: 08 June 2009, 12:02:54 »
ps mine is a saloon. I imagine its different rules again for an estate...?
