Author Topic: DAEWOO LANOS [97]INFO NEEDED.  (Read 4172 times)
unlucky alf
  • worksop, notts
« on: 20 June 2009, 20:53:26 »
 i know these cars are based on an astra but does anybody have any idea what model astra?, its just the brother-in-law has got one that failed the MOT on a busted rear spring, so ive got the job of fixing it but for a daewoo listed spring its £30 plus vat whereas the astra ones are nearly half that. :o i would take the old spring as a pattern but as there is a lump totally missing it wouldnt be much help, ideas anyone ::)
Re: DAEWOO LANOS [97]INFO NEEDED.
« Reply #1 on: 20 June 2009, 20:54:34 »
Astra F i believe they're based on.
amigov6
« Reply #2 on: 20 June 2009, 21:34:32 »
Do you try to be unlucky? Maybe one day your luck will change for the better.....
   That'll be the day   ooooooo!!!! ::)
webby23
  • Nottingham
  • MV6
« Reply #3 on: 20 June 2009, 21:37:17 »
The difference is only £15 mate, may as well get the proper Daewoo one for it..........??
unlucky alf
  • worksop, notts
« Reply #4 on: 20 June 2009, 21:55:27 »
i would webby but the thing is his working hours have been slashed & he is in danger of losing his house but needs the car for work, & excuse my ignorance but what is an astra F? :-/
unlucky alf
  • worksop, notts
« Reply #5 on: 20 June 2009, 21:56:55 »
thanks guy ;D ;D & dont ask me about my bathroom dilemma ive had this week :'( :'(
amigov6
« Reply #6 on: 21 June 2009, 00:21:28 »
   Ok i won't!
« Reply #7 on: 21 June 2009, 11:24:30 »
   Ok i won't!
But I will! Spill the beans then!
unlucky alf
  • worksop, notts
« Reply #8 on: 21 June 2009, 21:11:39 »
   Ok i won't!
o,k boys & girls,,,,,are you all sitting comortably??,,,then we`ll begin :)
got a plumber in to fit a bath in our pokey bathroom as it was a wetroom type of thing, well the first job was to take up ceramic floor tiles,,,hmmm easy enough but it what was under it that wasnt, the shower floor & water run-off was a preformed steel thing which was nailed to the floor >:(, so out with the angle grinder as trying to pull them out was lifting the floorboards [which was a worry], so as it was a shoehorn fit it was decided to cut it in 2 bits, we then lifted it & ,,,,ARGHHHHH!, where this shower has obviously not been water tight its leaked through to the floorboards, so i thought oh well id better get ready to buy a couple of new ones, by the time id finished i needed 4 floorboards, then to inspect the joists,,,,,hmmmmm should they really have the texture of sawdust??, so now its 4 boards & 3 joists that needed sorting :'(,
so sorted that mess out & the plumber begins, "i`ll just remove these bottom tiles & skirting so i can lift the floorboards a bit to run the pipes under the floor" he said, so with a little persuasion with a jemmy off came the skirting,,,,,,,complete with a huge lump of plaster with 3 rows of tiles attached >:( >:(,,,oh dear was his cry [spelt with 2 L`s & cks on the end] so now plastering required, next was the waste pipe for the bath,,,"just a little tap on the old pipe & replace" was the approach,,,,,ooops thats now a half brick needs fitting, so what started off as an afternoon job for the handyman & myself has ended up as 3 days work & ive still got the tiling to do,,,,,,,,yes unlucky alf is back on form ;D,,,,,i bet you wished youd never asked :D :D
