Author Topic: My life is hanging on an Eazi-Out....  (Read 7414 times)
« on: 21 June 2009, 21:27:25 »
Just doing some diags on the Ashtray..... I decided to remove and inspect the new plugs to see which one wasn't quite firing right.
Anyhow - re-fitting, using a torquewrench I may add - one of the spark plugs has broken off in the cylinder head  >:(
Basically the threaded bit has been left behind, and the electrode and washer broke free.
I am just hoping, because there is a hole in the centre of the bit that's broken off - that I will be able to get an easi out in there? My only worry is, it's quite deep in the head, so may not be long enough...
Any advise most welcome, before I set fire to it  :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: My life is hanging on an Eazi-Out....
« Reply #1 on: 21 June 2009, 21:40:51 »
I would get a new torque wrench James that one seems to be causing you no end of problems :(
Robski
  • Wigan,Gtr Manchester
« Reply #2 on: 21 June 2009, 21:41:14 »
James with the luck you've been having over the last week,the best advice I could give is gather your tools together and throw them in the bin ;D ;D ;D ;D ;D ;D
« Reply #3 on: 21 June 2009, 21:42:38 »
Eh? Not stripped anything else, recently...  :y
Halfrauds low range jobbie - set to 25nm.
The thing just snapped, no warning at all.
It was a brand new bosch plug - I wonder if it may have been faulty....
« Reply #4 on: 21 June 2009, 21:47:52 »
If I was you James, I would get someone else to hold my todger when I go for a pee ;D
« Reply #5 on: 21 June 2009, 21:54:37 »
You would, Pete. :D
In all seriousness - the porcelain part has come right out (intact, thank god), as has the hex bit - leaving just the threaded part, with a centre hole, in the head.
I can only pray a good easi out will remove it.
I've never used one before, obviously lots of grease to stop any filings entering the bore will be a must...
markey mark
  • SLady bitshorpe north lincs
« Reply #6 on: 21 June 2009, 22:14:30 »
bloody hell james glad i dont have your luck !!!  :o :o
« Reply #7 on: 21 June 2009, 22:16:58 »
Yeah, I think everyone probably is....
Found this picture on the net, from someone else who had the same problem.
Hopefully I can have the same outcome....
« Last Edit: 21 June 2009, 22:17:15 by JamesV6CDX »
markey mark
« Reply #8 on: 21 June 2009, 22:21:05 »
james please dont buy cheap easy outs had some nasty experiences at work with them ! if you want to borrow a very good easy out send me your address and will gladly post it to you in morning  :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #9 on: 21 June 2009, 22:21:09 »
As they say James if you fell in a barrel of boobs you'd come out sucking your thumb. ;D
TuBy's new whipping boy.
« Reply #10 on: 21 June 2009, 22:29:28 »
Who have you upset James?  Post it up here so the rest of us don't do the same!! :( :( :(
Good luck with the easyout mate  :y
« Reply #11 on: 21 June 2009, 22:43:36 »
Cheers mate - what make do you use?
« Reply #12 on: 21 June 2009, 22:57:04 »
worth rigging something up with a small tube and a hoover i reckon, just in case theres something dropped in the bore. Cant hurt....can it?
crazyjoetavola
« Reply #13 on: 21 June 2009, 23:04:20 »
 ;D ;D very good Captain  ;D ;D
« Reply #14 on: 21 June 2009, 23:06:37 »
Nope, I will definately be doing that :y
