Author Topic: Advice needed (Citroen Picasso cambelt)  (Read 3598 times)
mars
  • Cannock, Staffordshire
    • Vivaro Sportive BMW 330d
« on: 25 June 2009, 20:49:13 »
Our Citroen Picasso 1.6 petrol is due for a cambelt soon. I will be paying my local garage to do the job. Will it be advisable to have a water pump? Or is it just certain cars, ie Omegas on which it is recommended?
There is no such thing as bad beer, some beers are better than others.
Omegatoy
  • UK
Re: Advice needed (Citroen Picasso cambelt)
« Reply #1 on: 25 June 2009, 20:59:01 »
dont know about water pump biut do know your local garage better have a hertz meter to set the cambelt tension!!! only way you can do it in picasso!!!!
Ken T
  • Stockport
« Reply #2 on: 25 June 2009, 21:08:52 »
There is also talk about the crankshaft pulley failing on these, a known problem. you might have to have this done as well.
Ken
Toby
  • Ringwood, Hampshire
« Reply #3 on: 25 June 2009, 21:13:15 »
Have it done! For an extra £20 its worth it for piece of mind. If it seizes you can wave goodbye to your new belt and it will be money wasted.
I did the cambelt on my Xantia and did the waterpump at the same time. As I say, was only an extra £20 for the part and the engine has to be stripped that far to do the belt so only takes an extra 5 minutes to replace the pump. They can often go after having a new belt.
It's just not worth the risk.
