Author Topic: Spark plug conditions, stem seals, and piston ring  (Read 6828 times)
« on: 05 July 2009, 17:03:52 »
On the Astra. Put some new plugs in 1000 miles ago, just checked them, and this is the result:
Plug 1 - very white, with a few bright white deposits
Plug 2 - exactly the same.
Plug 3 - very very black. Some traces of wet oil on the spark plug thread.
Plug 4 - very white, with a few white deposits.
Car symptoms - puffing blue oil when revved after idle, or when cold. Doesn't puff oil when kept at high revs.
Spark plug 3 - would you say this blackness could be related to a crap stem seal(s) above this chamber?
Re the other plugs being very white - does this show that it's running lean? Or maybe too hot? (or both?).
Bearing in mind the car spends all it's life on LPG, I'm not even sure if they may be normal.
Compressions are all at 13.5 bar.
Do others agree it's time to take the head off for further investigation?
If I decide to do the piston rings at the same time - can I do this with the engine in the car? Is it literally a case of take sump off, unbolt piston and remove it from the top?
Thanks all, your replies are appreciated. I've never owned an Astra before and after this, possibly never will!
Shame, 'cos it's nice to drive!
Re: Spark plug conditions, stem seals, and piston ring
« Reply #1 on: 05 July 2009, 17:10:43 »
Interestingly, I just read that white deposits on the end of the plugs can be caused by dodgey stem seals also  ::)
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #2 on: 05 July 2009, 19:07:11 »
Normaly the plugs should be light brown in colour, if one is dark it could be stem seal, piston ring or head gasket not to sure but someone will know.
you should be able to take the pistons out with the block still fitted, as long as there is nothing blocking the bottom of the engine ie exhaust or a frame of some sort.
He who brakes Looses
To old to die young
« Reply #3 on: 05 July 2009, 20:12:59 »
Do they come out from the bottom, or the top?
Ghost
    • 2.6 V6 CDX Estate
« Reply #4 on: 05 July 2009, 20:29:06 »
depending on how far you strip your engine, if you take the crankshaft out you can get them out the bottom. but I would say its easyer to take and put them in the top. you will need a piston ring compressor to put them back in though. ( but you know that already )
www.machinemart.co.uk/shop/product/details/cht257-piston-ring-compressor/path/engine-service-and-re-build-tools
To old to die young
« Reply #5 on: 05 July 2009, 20:33:22 »
James, sooner or later you will take the head off..
so, do it.. ;D
« Reply #6 on: 06 July 2009, 11:20:20 »
I've been talking to lots of other astra owners with same issue.
Every time it has been a piston ring  :'(
I am going to change all of the rings on this one. Not a job I've ever done so wish me luck... helpful hints welcome!
I'm assuming, once head and sump off, it's just a case of cleaning bore, undoing the conrod cap from the journal, and pushing piston upwards?
Does the crank need to be in any set position to remove / refit a piston?
« Reply #7 on: 06 July 2009, 11:21:47 »
I also guess the bores will need honing - is this something I can safely do?
Sorry for all the Q's -  I've never removed a piston!
Ghost
    • 2.6 V6 CDX Estate
« Reply #8 on: 06 July 2009, 11:33:48 »
before you remove piston clean the top of one and c if there is an arrow or direction mark for refitting. and change all pistons rings.
To old to die young
Omega man 2
« Reply #9 on: 06 July 2009, 11:45:41 »
On an omega (guessing the astra is the same) the arrow is pointing to the front (cam belt) end of the engine. Lightly hone the bores and you might as well replace the shell bearings. I'm sure you'll have no problem removing the pistons on a WWD astra with the engine in place, I did it on a mig. :y
« Reply #10 on: 06 July 2009, 12:22:58 »
I would look for evidence of oil running down the valve stems on that cylinder before deciding it's the rings.
Other plug symptoms are fine IMHO on an engine running LPG. You won't get much colour to the plugs.
« Last Edit: 06 July 2009, 12:23:11 by Kevin_Wood »
« Reply #11 on: 06 July 2009, 13:15:12 »
Well, the head comes off either way - so, I'll check the seals as a first port of call...
If they're obviously the problem, I 'll leave the bottom end alone.
If not, unfortunately, I will have to bite the bullet...
For some reason I percieve piston changing to be a specialist job - I'm sure that's not the case, as long as time and care is taken....
smoothomega
  • Perth, Western Australia
  • 2002 2.2DTI CDX,
« Reply #12 on: 06 July 2009, 16:26:57 »
Removing and replacing the pistons is a straight forward job as long as care is taken, just be sure to use a good ring compressor and dont break them when you tap the piggies back into the block.
« Reply #13 on: 06 July 2009, 16:41:39 »
How does the ring compressor work - I'm aware it clamps around the rings and the piston then goes into the bore - does the whole assembly, including the compressor, go into the bore?
Martin_1962
« Reply #14 on: 06 July 2009, 17:39:55 »
You pop the piston out by gentle pushing with a wood rob - eg hammer handle.
Clamp up the rings and then gently bash it back in with the wooden hammer handle. Clamp says outside of the bore.
Fit NEW shells - rude not too
