Author Topic: 2.2 is back in action!  (Read 3178 times)
« on: 12 July 2009, 16:55:21 »
Glad to report my 2.2 is back in action, with a shinny new flexi join on  :D
Big thanks must go to MarkDTM for cutting the old one off and welding on the replacement, and for the interesting lesson in the art of welding, i owe you a lot of beer  :y
It runs super silent now, only slight problem is when the exhaust got hot after the main cat turn, it sometimes hits the heat sheild causing a vibration on first few revs from idle. so will 'adjust' the heatshield once its all cooled down.
Must say its good to be back in a manual saloon, even though the estate had a lot more power, i find the Elite estates wallow around too much, and with pattern exhausts don't sound great.
Was good fun putting my saloon back in the twisties  :)
Re: 2.2 is back in action!
« Reply #1 on: 12 July 2009, 16:56:22 »
Good suff mate, glad it's sorted  :y
« Reply #2 on: 12 July 2009, 18:03:46 »
i find the Elite estates wallow around too much :)
You ever driven a classic Rangie, Tunnie?  ;D :y
In all seriousness, I agree - the MV6 was much better handling than my previous Elite...
« Reply #3 on: 12 July 2009, 18:07:55 »
Good, glad you managed to summon up the strength to lift it back on  :y ;D
« Reply #4 on: 12 July 2009, 18:22:32 »
Amazingly i did!  ;D
I lifted it up and managed to get the gearbox bracket bolt in a couple of turns, with that weight taken i fed the down pipe up to the studs, slotted it on, it held, managed to get 1 on by hand from above, then all rest from underneath. Even managed to torque them up  :o
Only thing as mentioned i think the replacement all in is a few mm shorter, causing it to knock slightly on the heatshield when the exhaust got hot, managed to wiggle it a bit and push heat sheild back a bit, hopefully thats enough  :)
Thanks again  :y
« Last Edit: 12 July 2009, 18:23:55 by tunnie »
« Reply #5 on: 12 July 2009, 19:13:00 »
Blimey, Mummy allowed you to go under a car all alone :o
Seriously, good job :y
I too need to thank a certain Admin for a quick welding lesson - even though its gonna cost me a load of money ::).  Thanks Mr DTM :y :y
« Reply #6 on: 12 July 2009, 19:42:22 »
I guess you used a MIG welder  :-/ ...... what lesson do you need?  :-? Press & weld!  :y  :y  :y
« Reply #7 on: 12 July 2009, 20:25:46 »
That the difficulty is in setting up the machine, too hot, you burn though, too cold does not make the weld. And to 'push' the weld up in a zig zag motion  ;)  :y
« Reply #8 on: 12 July 2009, 21:39:56 »
and the correct wire feed.  ;)  ;)  ;)
Anyone can weld with a MIG set   ;D ...... TIG, MMA (stick to you  ;) :y) & gas take a little longer to learn.  :y  :y  :y
« Reply #9 on: 13 July 2009, 08:27:07 »
I find gas easier....
« Reply #10 on: 13 July 2009, 09:05:43 »
Gas must be a dying art these days, with the cost of inverter TIG sets coming down to relatively small money TIG is the future!  :y  :y  :y Plus you can weld stainless with TIG  ;)  ;)  ;)
« Reply #11 on: 13 July 2009, 09:51:20 »
You can weld stainless with MIG.....very tempted by a TIG/MIG/plasma cutter combi for home use.
« Reply #12 on: 13 July 2009, 10:55:06 »
I would take the off-cast MIG off your hands  ;)
I have some axle stands that need some feet to stop them sinking into the drive, could be some good practice  :y
