Which Welder
Started by TheBoy, 15 July 2009, 18:50:56
The Clarkes are the best all round hobby Migs, the SIP's have vey poor wire feeds.
Remember that 135-140A is the most you can run off a domestic 13A socket.
A 135TE is a nice unit (and you have used one before!)
Gas or gasless? Can get gasless from screwfix for £90.  Clarke 135A is £250 from machine mart.
QuoteThe Clarkes are the best all round hobby Migs, the SIP's have vey poor wire feeds.
Yeah, thats the £250 one I mention above. Reckon thats a good start? What about gasless - much cheaper.
On the upside, I do have a 10% code for machine mart
Welung666
Much cleaner, stronger weld with gas, especially if you use 02/Argon mix :y
Yep, much better weld with gas....and as said, Argashield is superb....but you have to consider your use and budget (that Clarke one has really shot up in price, I paid about 150 quid on a vat free day 3 years ago)
QuoteMuch cleaner, stronger weld with gas, especially if you use 02/Argon mix :y
Yeah, know why you have inert (or semi inert) gases. The gasless mig ones use a gas flux in the wire from what i can gather?
Indeed, which is quite a big compromise.
QuoteYep, much better weld with gas....and as said, Argashield is superb....but you have to consider your use and budget (that Clarke one has really shot up in price, I paid about 150 quid on a vat free day 3 years ago)
welcome to low interest rates  >:(
QuoteIndeed, which is quite a big compromise.
So the gasless (or gas in wire) type best avoided then?
Welung666
It's OK if you do a lot of welding outside in the wind. I tend to rig a windbreak if it's windy though as I prefer to use gas.
unlucky mark mv6
Totally agreed lee,but cant really comment on gasless as i have never used one.One advantage of the gasless i suppose is when your welding outdoors in a breeze.it wont blow the gas away and the weld bubbles up.
Welung666
Mine is gas/gasless and can run either way (with the correct wire of course), when using gasless I tend to weld more holes into my clothes than I do metal to metal ;D
Gasless spits more (the core only turns to a gas as its hot).
Never had a problem outside, I just turn the shield gas pressure up a bit.
And its Ar/CO2 not Ar/O  ;D ;D
If you wnat to move onto alloys etc then gas is the only way to go.....
unlucky mark mv6
A welder is designed to weld steal lee not clothes. ;D ;D :y
Welung666
QuoteGasless spits more (the core only turns to a gas as its hot).
That's what I meant but I was thinking about my mobile phone bill at the same time ;D ;D
