Author Topic: Fitting my lifters tomorrow.  (Read 3384 times)
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« on: 28 July 2009, 21:51:04 »
I've been told to soak them in oil overnight, should I?
And any tips on how to pull the old ones out without scratching the head or with out using the sucker thing in the Haynes book of lies.
Saving for one! All donations welcome, ask for details.
Re: Fitting my lifters tomorrow.
« Reply #1 on: 28 July 2009, 21:57:58 »
Just make sure you put all 23 24 back in again!  ;)  ;)  ;) ;D  ;D  ;D
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #2 on: 28 July 2009, 22:06:39 »
Cheeky git ;D ;D ;D
« Reply #3 on: 28 July 2009, 22:08:03 »
Cheeky git ;D ;D ;D
The joke is at someone elses expense!  ;)  ;)  ;)   :y
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #4 on: 28 July 2009, 22:12:54 »
Cheeky git ;D ;D ;D
Ah yes ::) ::) ;D  Anyway there's nothing wrong with only having 16 ::) :-[
« Reply #5 on: 28 July 2009, 22:15:14 »
Cheeky git ;D ;D ;D
Ooops! ::) Looks like the joke is on me then! I didn't notice you had 2 pots missing.  ::)  ::)  ;)  :y  :y  :y
« Reply #6 on: 28 July 2009, 22:28:44 »
Cheeky git ;D ;D ;D
Has it ever occurred to you that you might have too many in yours?  ;D
« Reply #7 on: 28 July 2009, 22:34:15 »
Cheeky git ;D ;D ;D
No! :-?
You can never ever have too many cylinders! As a minimum, you need at least more cylinders than doors!  :y  :y  :y
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #8 on: 28 July 2009, 22:37:16 »
Cheeky git ;D ;D ;D
No! :-?
Have to agree with that :y
Only driving a four pot omega cause I have a total of 0 years NCB. :D So once I've a couple of years I'll be leaving omegas behind and getting a nice v8 lexus :)
Ian_D
  • York
« Reply #9 on: 29 July 2009, 01:21:30 »
Do you need to run the new lifters in at all?
Was reading up the other day somewhere that if you need to fit new lifters, that you must fit a new camshaft, and then start the engine and vary the rpm between 2000-2500ish for 15 mins  :-?
I guess this is only on the old old engines? :-/
[size=12]
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #10 on: 29 July 2009, 08:34:45 »
Never heard of that :o :-/ Anyway if it come to that, at least I've two spare camshafts :y
« Reply #11 on: 29 July 2009, 12:57:00 »
You can prime the lifters by submersing them in clean oil and pumping the centre piston a few times (until air stops coming out the hole).
Not essential though.....and you dont need to change the cam shaft.
Why new lifters though?
« Last Edit: 29 July 2009, 12:57:26 by Mark »
Ian_D
  • York
« Reply #12 on: 31 July 2009, 18:34:26 »
It was regarding old v8 blocks (push rods).
Basically, the top of the tappets are flat when new. Once 'run in' they are very slightly domed inwards, and this causes the tappet to spin round as the camlobe passes over it, and thus wears the lifter evenly.
But again, that was regarding old pushrods, and maybe isn’t relevant now.... :-?
[size=12]
« Reply #13 on: 31 July 2009, 20:03:42 »
Thats not right!
The lifters have a nitrile hardened coat as do the cam lobes....wear that sub micron thick coat off and they dont last long.
The bit that makes them turn is the fact the cam tip has a slight slope on them
The running in procedue use to be because there were still un-polished nitrile coats on the cam lobes...they certainly didn;t wear.
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #14 on: 31 July 2009, 23:25:31 »
Had a couple of knackered ones. Made it sound like a diesel.
How long would it normally take for them to quiet down fully? I didn't prime them.
