Pages: 1 [2] 3  All   Go Down
Author Topic: A bad bad day Volume 2  (Read 10406 times)
Re: A bad bad day Volume 2
« Reply #15 on: 26 August 2006, 21:03:37 »
My day started bad, but improved. My coolant now appears fairly clear :)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #16 on: 26 August 2006, 21:13:27 »
 ;D ;D ;D at Ronnie
Not a chance of those headrests EVER getting out of the car now mate!!
hotel21
  • The Kingdom of Fife
« Reply #17 on: 26 August 2006, 21:24:29 »
On stubborn bits and pieces, I have used a combination of heat and freeze - heat from either oxy acetylene or a butane plumbers torch, coupled with a good blast with the freeze spray used for freezing central heating pipes while you fix a non-valved part.  The mix of heat and cold can uncement a joint, if you watch what you are upto.
Have also used a buckshee CO2 extinguisher, in lieu of the freeze spray!!  More spectacular, for sure, but end effect was a good 'un!!
What about a chisel and a heavy hand hammer to split the nut, if thats what you are stuck on?
Markie
« Reply #18 on: 26 August 2006, 21:31:59 »
I guess anything is worth a try - never had any sucess with the old chisel method, or for that matter the "hammer a smaller sized socket on"
Whats concerning me is that its BOTH sides and theres 3 on either side prohibiting me so its not just a lone stubborn nut....
Ive actually dropped the front axle and got those bolts out without breaking sweat!!
At the end of the day i only care about the engine so if i need to go angle grinding, I will..... ;D
« Last Edit: 26 August 2006, 21:32:43 by Markiec »
« Reply #19 on: 26 August 2006, 21:42:38 »
Give them a good soak overnight in pentrating oil. See what happens tomorrow...
Markie
« Reply #20 on: 26 August 2006, 21:44:13 »
im on it Jamie, along with beer number 4  :D
« Reply #21 on: 26 August 2006, 21:45:31 »
Aye, the Stella is flowing down my neck tonight as well :D
Markie
« Reply #22 on: 26 August 2006, 22:05:57 »
Cant be beaten...was toying with opening a bottle of Red but wife has banned me from having this in our new Lounge  >:(
Oh well stella it is ... wine is in the garage now in case tomorrow is a bad day.... ;)
« Reply #23 on: 26 August 2006, 22:08:09 »
tomorrow will be a better day... :)
RonaldMcBurger
« Reply #24 on: 26 August 2006, 22:24:33 »
You could try recruiting a new member from lane 3 of a motorway. Oh, sorry. That's been done..... ;D
Seriously Mark, I know what you are going through and it winds me up when it just won't undo. But, if it is a nut, use one of those 'grip' type sockets that dig in deeper and deeper the more you turn. Use a good 1/2 breaker bar and a scaffold pole on the end. It WILL bloody shift then.
Just a thought, but I found that the last time I tried to take an engine out of the car I couldn't undo anything, so I took the car off the engine instead! :o :-[ [smiley=tongue.gif] [smiley=vrolijk_26.gif] [smiley=vrolijk_1.gif] [smiley=lolk.gif] [smiley=happy.gif] [smiley=tekst-toppie.gif]
Gawd, this beer is good!
Markie
« Reply #25 on: 26 August 2006, 22:33:01 »
Heh He i think your lane 3 escapades will only be beaten by recruiting whilst flying......now theres a thought.... :o
The beer is smashing tonight......the bolts - are gonna get smashed.....er tomorrow...or the next day....was toying with going out to try again...but thats just silly!  ;)
« Last Edit: 26 August 2006, 22:33:40 by Markiec »
Hillper
  • Aylesbury
  • Werthers. Winter, too hard.  Summer, too soft.
« Reply #26 on: 27 August 2006, 00:23:08 »
Glad the beer worked guys!
See how much better it all seems now?
I just wish I wasn't at work right now.   >:(
Mods.  'Hillper boot release'.  Dimming mirror.  Cruise control. Rear parking sensors.  Becker/Rockford Fosgate/Infinity/Alpine audio.
Big Rod
  • Fife, Scotland
« Reply #27 on: 27 August 2006, 10:38:35 »
Yeah, best not to Mark! I'm testament to beer and tinkering not going well together after I nearly destroyed myself and a MKIII Cortina all at once years ago.
Any stuck nut I've ever come across has always responded well to the application of a huge ammount of heat followed by a massive ammount of torque. It's so satisfying hearing the twang of the little b*stard finally giving up!!
Remember not to pick the thing up off the floor afterward with the intent of throwing it in victory/anger!! I'm testament to that not being a particulalry good idea too!!  ::)
If I have to explain you won't understand!
RonaldMcBurger
« Reply #28 on: 27 August 2006, 11:07:49 »
Yes.. Mmmmm. The heat transfer problem......
I distinctly remember last month doing the wishbones and droplinks. Heat was required on the top droplink nuts and then they did indeed undo. I then grabbed the nut to put back on the now removed droplink (A. I have no idea why, and B. Not a good idea!). Having burned myself to the point of cursing loudly, I then took my anger out on the socket - which had become about 8,000,000,000 degrees too. Oh joy!!!! Double burns!!!! In real anger I grabbed the blowlamp to sling it down the road. Note here guys, two things: Firstly, turn the blowlamp off first as it is slightly warm when still on. Secondly, don't try to pick it up a second time because you dropped it (being so hot) and the flame is now burning your leg.
Oh yes, the benefit of heat and stuck nuts.  >:(
« Last Edit: 27 August 2006, 11:08:17 by RonaldMcBurger »
Markie
« Reply #29 on: 27 August 2006, 15:14:26 »
Right
My nuts are still stuck despite penetrating fluid being applied overnight  :o
So due to the various cuts and bruises and general frame of mind i am leaving this a few days untill my apprentice comes down from the Scottish Islands ( my dad is due on Wednesday)
To put it into perspective in half the time i have spent on thes nuts ( about 4 hours today) i have
Removed complete wiring loom - absolutley everything from dashboard, engine - stereo - everything.
Removed complete front and rear axle
Removed complete bul of dashboard
Disconnected clutch and gearbox connectors to engine
Without a hitch!!
Roll on wednesday
« Last Edit: 27 August 2006, 15:15:06 by Markiec »
Pages: 1 [2] 3  All   Go Up
