Pages: 1 2 [3]  All   Go Down
Author Topic: Omega Euro headlights  (Read 9437 times)
Welung666
Re: Omega Euro headlights
« Reply #30 on: 16 August 2009, 17:15:54 »
Doesn't the adhesive mirror film crumple up as you line the reflector curves?
I did the Fiesta headlights in 3 pieces. Made paper templates first then stiff card ones, cut out the mirror sheet then carefully fitted it using a brand new yellow duster to push the air out as I went. This mirror sheet is quite soft, a bit like the clear sticky backed plastic of Blue Peter fame ;) :y
SJKOO01
« Reply #31 on: 16 August 2009, 17:31:12 »
Where did you get the stuff from Lee ?.
or any chance of selling me a sheet or two please  ::) ?.
Mr.T
  • Ollanda
  • Look there...behind you in the mirror. Thats me
« Reply #32 on: 16 August 2009, 17:39:58 »
i would get a other set from the scrappies or other.  :P
Thizz iz german quality,  Ze red baron :p
Welung666
« Reply #33 on: 16 August 2009, 17:42:34 »
It's on a roll Matt, work out how much you need and I'll get it up to you, we can do a deal on the MAF from your local breakers if you fancy :y
SJKOO01
« Reply #34 on: 16 August 2009, 17:49:05 »
Sounds good to me, I'll see if I can get the maf off the car as soon as, unless someone else has had the same idea !!.
M
Omegadoha, Desert Member
  • Doha, Qatar
« Reply #35 on: 16 August 2009, 17:55:11 »
Well you certainly make it sound easy.  8-)
Welung666
« Reply #36 on: 16 August 2009, 17:58:57 »
Took me about an hour to cut the paper templates perfectly, then about another hour putting on the first side, 2nd one took just over an hour in total as I just turned the template over ;D
Welung666
« Reply #37 on: 16 August 2009, 18:00:17 »
M
If you pop over sometime I'll give you a hand doing them if you want Matt?
« Last Edit: 16 August 2009, 18:00:52 by Welung666 »
SJKOO01
« Reply #38 on: 16 August 2009, 18:03:39 »
M
Thanks for the offer, may take you up on that ?.
Welung666
« Reply #39 on: 16 August 2009, 22:16:44 »
M
Always happy to help matey :y, plus I'll have a set of templates ready for when I do mine ;D ;D ;D
SJKOO01
« Reply #40 on: 17 August 2009, 16:21:08 »
M
Ahh.... so that's the reason, and here's me thinking you were doing it out of the good of heart !  ;D  ;D .
Let you know when I've got the maf, though may be the weekend now chap.
Welung666
« Reply #41 on: 17 August 2009, 18:06:51 »
No probs :y
Pages: 1 2 [3]  All   Go Up
