Author Topic: Trafic wheel bearing take 2  (Read 2014 times)
« on: 23 August 2009, 21:31:38 »
My rear wheel bearings turned up, already in the discs, may have a bash at fitting meself done others, can you tell me, doesn't look like it's a tapered bearing, do these rear wheel bearings need to be tourqed up or just done up tight?
Someone said you may not have to as it's not tapered, if they do need to be tourqed anyone know what the tourqe setting is, looked on the net can't see nothing  :(
Re: Trafic wheel bearing take 2
« Reply #1 on: 23 August 2009, 21:42:16 »
They will certainly need to be set with a torque wrench. If it's a sealed bearing it's normally quite a high setting and you'll need a new hub nut.
« Reply #2 on: 23 August 2009, 21:44:41 »
Thanks mate.
Pete Elite
  • Uxbridge, Middlesex
« Reply #3 on: 24 August 2009, 00:35:02 »
And a big torque wrench ;).
