Author Topic: Clunk On Zafira A  (Read 6731 times)
tofer
Re: Clunk On Zafira A
« Reply #15 on: 11 August 2009, 14:14:14 »
I ended up getting the whole engine mount in the end. It was a pain extracting the stud from the bracket as well.
MutantCav
  • Gainsborough
« Reply #16 on: 11 August 2009, 20:37:01 »
Wouldnt a failed engine mount fail the MOT?
Welung666
« Reply #17 on: 11 August 2009, 20:39:26 »
Only if they saw it ;)
MutantCav
  • Gainsborough
« Reply #18 on: 11 August 2009, 20:52:36 »
How can you tell if its failed?? Both look pretty solid to me, rubber looks good...how do I test it?
Welung666
« Reply #19 on: 11 August 2009, 20:59:48 »
Easiest way is a hefty chunk of wood and a trolley jack, just gently take the weight on the jack with the wood inbetween near each mount then check for erronious gaps :y
MutantCav
  • Gainsborough
« Reply #20 on: 11 August 2009, 21:09:14 »
Dont mean to sound dim but erroneous gaps where??
Welung666
« Reply #21 on: 11 August 2009, 21:18:39 »
between the metal plates and rubber sections that are supposed to be bonded together ;) :y
MutantCav
  • Gainsborough
« Reply #22 on: 11 August 2009, 21:21:37 »
Ok sorted...thanks :) I will have a look in the morning :y
« Last Edit: 11 August 2009, 21:22:12 by ShieldOfSteel »
MutantCav
  • Gainsborough
« Reply #23 on: 26 August 2009, 00:17:41 »
Finally got to the bottom of it...surprisingly the engine mounts are ok...all checked out as it should...apart from one minor little thing that a quick check by the mechanic doing the cambelt/tensioners/water pump today picked up...
All 4 of the bolts holding on the subframe had worked their way loose and needed 3-4 turns to tighten them!  :-?  :D
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #24 on: 28 August 2009, 01:45:40 »
Indeed, engin mounts are the favourite.
Shitroen is definately not the way to go  ;D
Yeah, instead of WWD. you've gone for WFM :y
