Author Topic: front suspension  (Read 1967 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
front suspension
« on: 28 August 2009, 22:13:17 »
repaced recently idle arm, drop links & suspension arms. my ? is what is the arm called on the o/s, the one that comes from the steering box. plus if anyone knows the part No.  cheers in advance
Pete Elite
  • Uxbridge, Middlesex
Re: front suspension
« Reply #1 on: 29 August 2009, 00:42:53 »
Which bit in the picture do you mean?
  12  ARM,STEERING,INTERMEDIATE (NLS.- USE 9195731)
  14  BRACKET,INTERMEDIATE STEERING ARM
  7  -JOINT,ASSY.,OUTER,RH (LONG) (NLS.- USE 90510654)     1  90473812  3 24 060
7  -JOINT,ASSY.,OUTER,RH (LONG)   -X1999999
 1  90510654  3 22 180
7  -JOINT,ASSY.,OUTER,RH (LONG)   Y1000001-
 1  9193099  3 22 005
7  -JOINT,ASSY.,OUTER,LH (LONG) (NLS.- USE 90510653)     1  90473811  3 24 059
7  -JOINT,ASSY.,OUTER,LH (LONG)   -X1999999
 1  90510653  3 22 179
7  -JOINT,ASSY.,OUTER,LH (LONG)   Y1000001-
 1  9193098  3 22 004
8  -JOINT,ASSY.,OUTER,RH (SHORT) (NLS.- USE 90510652)     1  90496015  3 24 062
8  -JOINT,ASSY.,OUTER,LH (SHORT) (NLS.- USE 90510651)     1  90496014  3 24 061
9  --NUT,HEX.,M12 (NLS.- USE 90538058)     2  90304096  3 53 996
9  --NUT,HEX.,M12
raywilb
    • Citroen C4 Cactus
« Reply #2 on: 29 August 2009, 01:24:31 »
ta a loads. ive fitted a new steering arm 12 to 10 n/s. i now need to fit likewise to the o/s but i,m led to believe its a shorter arm on a td , but not sure.on my hols in a few of days  & local stealers need a week :y :y
