Author Topic: bloomin locking wheel nuts  (Read 6642 times)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« on: 28 September 2009, 18:49:02 »
trouble ive had today, locking wheel nut stripped off, not the type you can knock a socket onto. tried drilling it off, drills have a better chance of going through butter. so, dismantled the caliper from the inside, off with the bearing dust cap & took the whole bloomin lot off, wheel, disc, hub & caliper bracket. was a bit of a jiggle. good job i have a spare set of everything. moan, moan.  :(
serek
  • huntingdon
    • 3.2 mv6
Re: bloomin locking wheel nuts
« Reply #1 on: 28 September 2009, 22:15:25 »
I had same problem before >:(
I start drill using 4mm,5mm,6mm and 8mm then use 50 or 55 torx big hammer bit of luck and job done :y
« Last Edit: 28 September 2009, 22:15:50 by serek »
Welung666
« Reply #2 on: 28 September 2009, 22:22:51 »
Is it one of the spinning collar locking rings?
The Red Baron
« Reply #3 on: 28 September 2009, 22:26:58 »
nope. its solid with 4 holes for prongs.
« Reply #4 on: 28 September 2009, 22:27:15 »
Are there any without the spinning collar? The lock bolts originally fitted to my car were the type with 3 holes in the face - the kind that ATS/Kwik Fit/etc will break the pins off the key for you with their windy gun - those now fitted are the later cake cutter type. Both types have a spinning collar, but the earlier type was somewhat thinner tha those now fitted.  :y
Welung666
« Reply #5 on: 28 September 2009, 22:29:34 »
Can you not hammer on a suitably undersized impact socket then? Or get a set of removers?
The Red Baron
« Reply #6 on: 28 September 2009, 22:30:07 »
yep, thats whats happened, also made a mess of the locking nut aswell :-/
The Red Baron
« Reply #7 on: 28 September 2009, 22:31:17 »
not enough of a coller to knock owt on really
Welung666
« Reply #8 on: 28 September 2009, 22:31:57 »
The 2.2 I'm breaking has the 3 prong affair and no key! My ½" cold steel chisel and a suitable impact socket soon dealt with that problem ;)
Welung666
« Reply #9 on: 28 September 2009, 22:33:16 »
What about drilling a hole central and a decent stud extractor?
The Red Baron
« Reply #10 on: 28 September 2009, 22:33:18 »
dont want to damage the mv6 wheel if i can help it as the nut is deep into them
Welung666
« Reply #11 on: 28 September 2009, 22:34:23 »
It'll be less damage than a gas axe ;D
« Reply #12 on: 28 September 2009, 22:36:33 »
How about these? http://www.machinemart.co.uk/shop/product/details/5-piece-bolt-grip-set-expansion-set/path/socket-sets-sockets-tool-sets  :-/  :-/
The Red Baron
« Reply #13 on: 28 September 2009, 22:37:02 »
very true, i think i will have to buy some decent drills then give it a go with the torx bit as serek suggests. :y
Welung666
« Reply #14 on: 28 September 2009, 22:40:47 »
Buy a cheap Halfrauds set that you don't mind shearing off then, you don't want your best set of 'Draper's' getting damaged ;) ;D ;D
