Author Topic: leak off pipes  (Read 2459 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
leak off pipes
« on: 08 October 2009, 23:57:05 »
does anybody know how if poss to blank off a leak-off pipe to make the blank-off end or is it buy a kit that contains a blank . 2.5 td is the car in ? .cheers  :)
Welung666
Re: leak off pipes
« Reply #1 on: 09 October 2009, 05:47:00 »
Do you mean the rubber cap on number 6 injector?
I've got one here if you do matey :y
raywilb
    • Citroen C4 Cactus
Re: leak off pipes
« Reply #2 on: 09 October 2009, 08:12:57 »
yes thats it .i will buy one if nobody can come up with a tried & tested leak-proof method of making one out of a length of tube - cheers  :y
Welung666
Re: leak off pipes
« Reply #3 on: 09 October 2009, 08:22:13 »
Do you need it longer or something? I'll post you this one out for nothing mate. If you do need it longer I've got some strong vacuum pipe that fits the tubing perfectly that I can stick a couple of inches in with the end cap. ;) :y
Re: leak off pipes
« Reply #4 on: 09 October 2009, 10:09:56 »
They come in the kit... And I've made them before by taking a long length of leak off pipe and bending it over, but it was only as a temporary fix :y :y
raywilb
    • Citroen C4 Cactus
Re: leak off pipes
« Reply #5 on: 10 October 2009, 07:39:19 »
i never have bothered  with the  kit , just cut lengths to suit , in six years its only the 2nd time ive needed a blank, just wondered if there was any ideas out there .
 :y :y :y
