Author Topic: HG failed  (Read 2852 times)
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
HG failed
« on: 09 October 2009, 22:51:08 »
Just got back from 13 straight hours in the omega after a 430 mile round trip.
With about 290 miles left it started overheating and idling rough, so, pulled over to have a look, expansion tank empty, stinking of exhaust fumes,white smoke and mayo on the dipstick, put water in and it starts bubbling  >:(
Spent the next 290 miles at a steady 50 mph stopping every 10 mins or so to check add oil/water/money in the swear jar :'(
So I'll be taking the head off tomorrow to see where it stands, first of all what could make it go after just 9000 miles?  :-?
And secondly what do I look out for on the head to see if it might need skimming?
So whats the record distance for a knackered HG :D
Saving for one! All donations welcome, ask for details.
deviator
  • Chesterfield
Re: HG failed
« Reply #1 on: 09 October 2009, 23:08:52 »
There are several reasons a HG can fail so soon...
1. Faulty/wrong Gasket
2, Block oil/water way (pressure build up)
3. Warped head
4. Dirt/debris in the way
5. Wrong torque settings/order (or over stretched bolts)
Did you have it skimmed last time? Or did you see any signs it had been skimmed before? As a head can only be skimmed twice. (normally).
See where it's gone and the hopefully the type of damage will help to suggest the fault.
Re: HG failed
« Reply #2 on: 10 October 2009, 08:36:47 »
3. Warped head
The top of that list should be old coolant! Thats the biggest killer of 4 pot HG's, make sure the anti-freeze is changed regually & has a good 50/50 mix.
Re: HG failed
« Reply #3 on: 10 October 2009, 11:03:45 »
Gasket's only been on there 9k so I would hope the coolant was OK.
I would say the head and block surfaces need some careful checking. Either that or the head's gone porous.
Re: HG failed
« Reply #4 on: 10 October 2009, 11:06:21 »
Ah did'nt know it had already been done. I should really read the whole post  ::)
Possibly the head was not cleaned up well enough to ensure a good seal?
« Last Edit: 10 October 2009, 11:07:18 by tunnie »
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
Re: HG failed
« Reply #5 on: 10 October 2009, 11:35:50 »
What about going almost flat out for extended periods  :-[ :-[
KillerWatt
Re: HG failed
« Reply #6 on: 10 October 2009, 12:16:16 »
Define "almost flat out"
PS
Next time a car loses water on you, do NOT put water in while it is that hot. All that will achieve is to greatly increase the chances of even further damage.
Re: HG failed
« Reply #7 on: 10 October 2009, 12:43:17 »
PS
Agreed. I stopped for a guy in a Frogeye at Le Mans once. Gave him some water which he poured straight in while the grease on the engine was still smoking. Came straight back out like a geyser!
Him: "it's a £30 a+ engine from a scrap yard. I don't care"
Me: "You're 500 miles and a ferry ride from home."   ;D
I would have a careful look at the gasket when you get it off. See where it went. This will give you a clue as to the problem.
As it has overheated I would take the head to an engine workshops and get them to check it's true / skim as required.
Oh, and, in standard tune, an engine in good condition will take a lot of punishment, believe me. ::)
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
Re: HG failed
« Reply #8 on: 10 October 2009, 18:33:07 »
Right, its off, clynder No. 3 was wet, gasket split by it on the passenger side  >:(
Head doesn't appear to be damaged/warped but will take it for a second much better opinion.
Re: HG failed
« Reply #9 on: 12 October 2009, 08:34:39 »
Post a picture of the head face so we can see if there is any wasteage around the coolant passages.
The fact its gone around a middle pot may hint at a warped head (check with a good straight edge!)
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
Re: HG failed
« Reply #10 on: 12 October 2009, 17:27:49 »
Just dropped it of at an engine specialist this morning to be pressure tested and skimmed if neccessary. He phoned earlier and said it was probably caused by overheating  :-?
I checked it before it went in with a steel ruler and appered to be fine, but I'll wait for the verdict tomorrow  :)
