Author Topic: lsd  (Read 3639 times)
robbo2345
  • Norfolk
  • the nature of the beast
    • 01/03 elite 2.6 estates
lsd
« on: 25 October 2009, 11:43:44 »
 :-? :(how can u tell if you have a LSD fitted ?
life is too short ...... so live it every day !!
Re: lsd
« Reply #1 on: 25 October 2009, 11:44:44 »
unless your car is x-plod, it won't be fitted.
ENFIELD_MV6
  • Enfield
  • previously from leicestershire
Re: lsd
« Reply #2 on: 25 October 2009, 11:57:01 »
???????? drugs are illegal mate  8-) ::) leave lsd alone
waspy
Re: lsd
« Reply #3 on: 25 October 2009, 12:00:05 »
Unless someoen's fitted one before you owned the car ;)
The best way is to wait for a wet day (shouldn't have to wait long) Stop & then boot it in a staight line, if it snakes from side to side you have one if you get even skid marks you don't have one. My old Trans-Am's had them & they were sooo easy to snake :D :D
yatesDELTA
Re: lsd
« Reply #4 on: 25 October 2009, 12:25:13 »
surely its better to not have LSD then?
would Traction Control need to be off for it to work?
is the TC on when the light is on dash or off?
robbo2345
  • Norfolk
Re: lsd
« Reply #5 on: 25 October 2009, 12:25:20 »
 :y :y cheers guys will give it a go and i never had any interest in drugs and arnt gonna start now its a mugs game lol .
Re: lsd
« Reply #6 on: 25 October 2009, 13:42:15 »
Depends what type of LSD you have, though. Some are more subtle and will just leave a number 11 on the tarmac. Without an LSD you will often just spin one wheel. Best way is to do as you suggest but on full lock, with plenty of space, and see if the car rotates around the front inside wheel or just drives in a circle with the inside rear wheel on fire. ;)
pedroMV6
  • York
  • Der Metzgermeister
Re: lsd
« Reply #7 on: 25 October 2009, 13:53:51 »
Pull driveshafts out of diff - if you can see a X then you got LSD. :y
Switch TC off, boot it from rest so wheels spin - number 11 = LSD :y
Fishtailing in the wet only tells you that the rear end is loose...........
pedroMV6
  • York
Re: lsd
« Reply #8 on: 25 October 2009, 13:56:00 »
IIRC, could be specced when ordered new.
ENFIELD_MV6
  • Enfield
Re: lsd
« Reply #9 on: 25 October 2009, 13:56:59 »
very true indeed i could not agree more
waspy
Re: lsd
« Reply #10 on: 25 October 2009, 15:04:06 »
I've just remembered that Pontiac's have a ali tag on the diff with a serial #. You could cross reference to see if the car has a LSD. Vauxhall/Opel are GM so maybe :-/ :-/ Have a look :)
waspy
Re: lsd
« Reply #11 on: 25 October 2009, 15:05:59 »
My rear end is never loose :D
pedroMV6
  • York
Re: lsd
« Reply #12 on: 25 October 2009, 15:19:36 »
Mine was after the booze last neet - ooh, me arse grapes! :D
waspy
Re: lsd
« Reply #13 on: 25 October 2009, 15:21:19 »
 ;D ;D
