Author Topic: s reg ford fiesta key bent  (Read 6103 times)
trainastock
  • st neots  cambridgeshire
« on: 27 October 2009, 17:04:00 »
as the title says daughter brought the car with only one key
i think its not the main key ,this one is bent and due to split out of the holder
wear could we get a replacement  fords or any key cutter  any help would be great :y :y :y
Tim7
  • Wiltshire
Re: s reg ford fiesta key bent
« Reply #1 on: 27 October 2009, 17:20:50 »
You should be able to get a replacment key at a high street key cutter, got one for my mum a few months back about £10 i think. some can do key with chip in or you can break of the old key tab and stick it under the cover by the ignition behind the steering wheel so car will still start.
« Reply #2 on: 27 October 2009, 17:35:02 »
Don't Fords have a master red key?  :-/  :-/  :-/
trainastock
« Reply #3 on: 27 October 2009, 17:37:29 »
on some models theres a red key with a chip in it , she was only given one key  :(
« Reply #4 on: 27 October 2009, 17:41:34 »
Don't you need the red key to teach any subsequent keys .....  :-/ :-/  :-/   :-/
trainastock
« Reply #5 on: 27 October 2009, 17:58:56 »
dont know might get it  one cut , dont want to go to fords they will charge the earth  :(
Welung666
« Reply #6 on: 27 October 2009, 18:39:31 »
Go to any decent locksmith and get a couple cut for about £8 each then cable tie bent one to the ignition barrel. Save's you getting them programmed :y
That's what I did on my mom's old Fester when she bent hers.
trainastock
« Reply #7 on: 27 October 2009, 19:18:15 »
excellent will do that
once again oof members have helped cheers  :y :y :y
rob in gib
  • Plymouth
    • Jaguar S type 3.0
« Reply #8 on: 27 October 2009, 19:34:03 »
i have just got a new key cut for my company transit blank came with holder for chip
took a bit of digging with a small screwdriver to get chip out of old key
popped into new key clicked shut and hay presto all for 12euros  :y
Just chilling in the sun. I wish back in the rain like everybody else
KillerWatt
« Reply #9 on: 27 October 2009, 19:44:25 »
S reg was the cut-off year when Ford did away with the "red" key malarky.
Look at your "black" key and tell me what colour chip it has (red or blue).
KillerWatt
« Reply #10 on: 27 October 2009, 19:45:09 »
And if your car gets nicked, consider your insurance void at that point!
trainastock
« Reply #11 on: 27 October 2009, 19:54:33 »
its a black key with a small red chip in the corner  :y :y
« Last Edit: 27 October 2009, 20:11:31 by trainastock »
« Reply #12 on: 27 October 2009, 20:07:40 »
it is red  :y
Which I think means it should have a red key, my Scorpio had 2 red chips in 2 of the keys other key was red.
KillerWatt
« Reply #13 on: 27 October 2009, 20:10:55 »
it is red  :y
Any buttons on the key, if so...how many?
trainastock
« Reply #14 on: 27 October 2009, 20:13:47 »
 no buttons on key just a small red chip on key :y
