Author Topic: brake drums  (Read 4866 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
brake drums
« on: 28 October 2009, 16:40:14 »
bit of advise please  :y
been given a citroen ax
rear near side drum is siezed on solid.  ( hand brake solid )
trying to remove the drum i have tried  ............... in no perticular order ...........
beating the sh*t out of it with a 3 pound lump hammer. ( no luck but very satisfying  :y :y )
removed hub cap and circlip and tried to undo the 32mm nut ........... idea was to to put the wheel on and spin it all off in one go  :y ( is the nut on a standard thred ??  ............. eh bent a 2 foot long piece of scaffold pipe on the t bar and socket  :'( :'(
relieveing some of the pressure by undoing the bleed nipple    :'(
i have not got a impact gun and socket but i do have a gallon of unleaded and a box of matches  :-/
any advise would be good
cheers steve
waspy
Re: brake drums
« Reply #1 on: 28 October 2009, 16:48:45 »
cheers steve
If i need any help undoing a problem nut/bolt i'll give you a shout :D ;D
Welung666
Re: brake drums
« Reply #2 on: 28 October 2009, 17:04:16 »
I got middle daughter a saxo for her 17th. It had been parked on someones drive for nearly a year when I picked it up and both rear brakes were solid. Managed to beat the one into submission with a lump hammer, the other wouldn't budge. So I dragged the locked wheel on the trailer with lots of revs. Ended up getting a cold steel chisel to it in the end and splitting the drum.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: brake drums
« Reply #3 on: 28 October 2009, 17:12:30 »
i'm only working on it because miggy is poorly  :'(
thought about drilling a hole in the back plate and carefully inserting a extention bar from my socket set and ..........................................
...................... beating the sh*t out of it with my lump hammer  :y :y :y
waspy
Re: brake drums
« Reply #4 on: 28 October 2009, 17:17:53 »
 ;D ;D ;D ;D
Some one had better take all hammers away from you ;)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: brake drums
« Reply #5 on: 28 October 2009, 17:32:56 »
no ............... there all mine   ;D ;D ;D
seriously though .............. need to get this thing off  :y
it was solid but after a beating ............ it freed of anough to drive it back  :y
not had a car now for 5 1/2 weeks  :'( :'(
was given it because other then the rear brakes / handbrake cable and a few digs and rust spots, its in good nick and cheep to tax / insure / run  :y
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
Re: brake drums
« Reply #6 on: 28 October 2009, 21:35:09 »
The only way of getting the drum off is by removing the 32mm nut (it is a standard thread).  The circlip holds the bearing into the drum so if you have to drive it anywere put it back in first.   Once you have the nut off slacken the handbrake cable and try hitting it whilst levering it at the same time. Chances are this still wont work and you'll have to get a slide hammer on it.
hth
lee
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: brake drums
« Reply #7 on: 29 October 2009, 15:43:04 »
and the fun goes on ..................... tried to remove one of the front wheels this morning and sheared off one of the studs  :'( :'(
anybody got a pushbike with a ladder rack i can borrow ?   :'( :'(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: brake drums
« Reply #8 on: 30 October 2009, 13:15:26 »
in even deeper sh*t now  :'(
the citreon ax is f**ked  >:( >:( :'( :'(
scrapping it  :'( :'(
thanks for all help and advise
ENFIELD_MV6
  • Enfield
  • previously from leicestershire
Re: brake drums
« Reply #9 on: 30 October 2009, 13:29:52 »
jesus aint had a good time whats gone t1ts up now matey
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: brake drums
« Reply #10 on: 30 October 2009, 13:42:02 »
2 x  brake pipes
1 x cv boot
1 x front wheel hub
1 x handbrake cable
1 x small patch of welding to be done ( and you just know that when you start digging at it, the hole will GROW  :'(
2 x tyres ( side walls cracked)
the amount of sh*t that i've been through in the last 5 years is crazy  :'(
all i can say is i must have been a real basta*d my past life  :'(
attila the hun ............ hitler .............. thatcher ............. or even all three !!
