Author Topic: Flat battery  (Read 5297 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Flat battery
« on: 25 October 2009, 12:17:29 »
Reading 11.47v, only 12 months old as well :(
I like red cars
Re: Flat battery
« Reply #1 on: 25 October 2009, 14:43:53 »
Your alternator OK? Anything powered up that shouldn't be? You've not been supplying power to your caravan have you & flattened it?  ;)  ;)
Welung666
Re: Flat battery
« Reply #2 on: 25 October 2009, 14:54:07 »
B, I've got the one off the 2.2 here, fully charged and holds it if you want it? :y
omegadti
  • Glasgow
    • omega dti
Re: Flat battery
« Reply #3 on: 25 October 2009, 14:57:25 »
I have just had a problem with mine - showed good voltage when charged but not enough power to start the car - the battery was less than 2 years old so sent it back and they confirmed a faulty battery and an offer of replacement, or refund as I had replaced the battery while waiting for the answer.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Flat battery
« Reply #4 on: 25 October 2009, 17:42:49 »
Everythings fine, alternator charging to correct voltage OK.
MarksDTM looked at it about 12 months ago, found a sticking relay to the rear aux. socket that was draining it, relay was removed.
This car is on it's 4th battery (counting the orig.) currently running on a genuine 70 amp Vx battery not their cheapo one.
Never owned a car that drains batteries so much. >:(
Charging it up at the moment, running on the spare.
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Flat battery
« Reply #5 on: 25 October 2009, 17:43:56 »
Thanks for the offer, it's OK, I've got a spare that I keep fully charged.
I like red cars
Re: Flat battery
« Reply #6 on: 25 October 2009, 17:45:52 »
did you check the charge at the battery? mine had a corroded lead running from the alternator.
The alternator itself was chucking out the right power, but not everything was reaching the battery. Replacement terminus on the positive has fixed it. Using a Vx Go battery now, even has the green light on it  :o
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Flat battery
« Reply #7 on: 25 October 2009, 17:54:00 »
Yup, no corrosian anywhere.
I like red cars
pedroMV6
  • York
  • Der Metzgermeister
Re: Flat battery
« Reply #8 on: 25 October 2009, 18:14:05 »
Same problem - and worse - with my Carlton.
it would drain overnight and even after a full charge, wouldn't start the car twice in a day.
Repaced starter motor, then alternator.
Replaced battery, still the same.
Voltage readings were spot on.
After a few months, I renewed all the wiring (because GM wire of that era is crap, it corrodes inside the sheathing and goes hard) from battery - alternator - starter and still did it.
Took new battery (a 18 months old by then) to be checked, 12V as it should be, but not many amps.
Tester showed me that there was one (or more) dead cells.
OK, so bought a bigger battery - Varta 70A, but higher CCA than old Carlton battery. Alternator charges it just fine.
He said the reason that the old battery could have worn out so quickly was dodgy main cables (the ones I had replaced after fitting previous) battery, or (and to be honest, more likely), bought a duff battery to start with.
« Last Edit: 25 October 2009, 18:16:07 by PedroMV6 »
Re: Flat battery
« Reply #9 on: 25 October 2009, 18:32:12 »
i'm not likely to think of anything the master would not have checked.
Only thoughts,
are the battery clamps crimped to the cables firmly? Not loose or getting hot?
Kevin Woods battery guide is very comprehensive it seems to me. Worth a go if you have a meter?
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Flat battery
« Reply #10 on: 25 October 2009, 18:59:59 »
Only thoughts,
Yup, everythings been checked.
I like red cars
Re: Flat battery
« Reply #11 on: 25 October 2009, 19:03:02 »
Intermittent fault draining it perhaps? How long had it been standing since last used?
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Flat battery
« Reply #12 on: 25 October 2009, 19:14:58 »
24 hours.
I like red cars
KillerWatt
Re: Flat battery
« Reply #13 on: 25 October 2009, 19:21:00 »
24 hours.
My old man had an intermittent fault just like this years ago, turned out to be the manifold heater relay intermittently sticking on.
Now I know the Mig doesn't have a PTC, but it does have other high current devices that are fed via relays (eg, heated screen).
I'd also stick an ammeter in series with the battery and measure the quiescent current.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Flat battery
« Reply #14 on: 25 October 2009, 19:21:45 »
I'll have a proper investigation tomorrow, didn't have alot of time today.
Maybe another trip to Nottingham, and get the old AVO on it, again. ;D
I like red cars
