Author Topic: car jack problem  (Read 2627 times)
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
car jack problem
« on: 31 October 2009, 20:42:13 »
while doing a wee thank you job on my mates pug ,he un screwed the release valve too much and  it lost some fluid , now it wont jack to good
can i refill it safely :question
dieseldonicely
Re: car jack problem
« Reply #1 on: 31 October 2009, 20:50:25 »
You really need hyraulic fluid of some description. I have used ordinary engine oil in the past though - different types of oil have different characteristics & you shoul use the correct type.
I can't recommend any cos mine came courtesy of work  ::)
« Reply #2 on: 31 October 2009, 20:52:33 »
i have one of those jacks, the arm for it is a slot fit if i remember correctly?
I bought a fat new 3 ton jack, with a much bigger lifting plate. It was spring loaded, no little valve thing, much more substantial. I was always nervous jacking up a 2 ton car with those little things.
Maybe time to treat yourself?  :)
« Last Edit: 31 October 2009, 20:53:08 by tunnie »
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #3 on: 31 October 2009, 22:21:16 »
We used to use brake fluid for the one at work and we never had any problems with it.
He who brakes Looses
To old to die young
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #4 on: 31 October 2009, 22:25:00 »
As long as there are no leaks in your jack as brake fluid is very hydroscopic.... trolley jack oil is readily available in most factors :y
« Reply #5 on: 31 October 2009, 23:06:26 »
so .... that'll be hydraulic oil then ....   ;)  ;)   ;) :y
Omegadoha, Desert Member
  • Doha, Qatar
« Reply #6 on: 02 November 2009, 16:37:17 »
The difference between a giraffe and the hydraulic jack is that the giraffe has high 'dangle berries'. ;D ;D Sorry couldn't resist. It's obviously approaching my bedtime.
waspy
« Reply #7 on: 02 November 2009, 16:40:17 »
Good night :P ;D
« Reply #8 on: 02 November 2009, 17:11:06 »
The biggest concern would be picking an oil that won't degrade the seals IMHO. Engine oil might. I would say brake fluid or ATF would be a safer bet.
Jack oil is probably one of the above, marked up and sold in very small quantities - just like lawn mower oil. ;)
« Reply #9 on: 02 November 2009, 18:49:11 »
Its normaly an ISO 32 hydraulic fluid....available from any factors or good industrial suppliers.
