gas conversion on the mig
Started by nick v6, 05 November 2009, 10:43:16
nick v6
im thinking of sticking a lpg kit on the mig
whats best to look out for and what sort of price would i be looking at
i would be fitting it myself :y
Stag Kit is used by many, good price works well on the V6.
Around £700-£800 all in.
QuoteStag Kit is used by many, good price works well on the V6.
Seconded. PM Lazydocker for details. Plenty of conversion pics on this site. Here's one for starters: http://www.omegaowners.com/forum/YaBB.pl?num=1216678718  :y
I think hats off has to go to your conversion Kevin, for me its the best conversion on here. Shame i can't find the pictures  :(
QuoteShame i can't find the pictures
That's what the link was for. ;)
See above.
See above.
*looks blankly at Sky's CoCo Milk from the coffee machine.
Think they drugged it  ;D
See above.
Wouldn't be surprised. :-X
kevin
And some pictures of mine... Not as complete as Kevin's pictures but you get the idea :y :y
http://www.omegaowners.com/forum/YaBB.pl?num=1219174789
I reckon you should budget £750 with a 4-hole cylinder tank, £850 with a spare wheel tank... That should leave you a bit spare if you find you need to replace anything whilst you're working in there.
The car must be running perfectly before you even start adding another item which could go wrong :y :y
nick v6
ive been offered a complete kit that was fitted to a 3litre v6 frontera last year
Quoteive been offered a complete kit that was fitted to a 3litre v6 frontera last year
and?? need more info than that.
make? model? mixer? sequential? price? millage used for? type tank?
nick v6
ag zenit is the make of it :-?
Using a second hand kit is obviously going to make it much harder. I wouldn't consider it unless:
1) It comes with all software, leads, etc. to adjust the mapping (especially if from a different engine size) and to debug the system (look at voltages, temperatures, pressures, etc)
2) It comes with a wiring diagram and fitting instructions.
3) All components meet the current ECE67.01 standards and are able to comply with the latest LPGA COP.11. This is important as it will allow you to get the install certified if your insurer requires it.
4) It is complete - right down to the nozzles from the inlet manifold.
5) It is a modern Multipoint injection setup (SGI)
Have a look here for examples of what you should be getting:
http://www.autogasmarket.com/english/shop/category/11.html
Even then, I would replace all rubber hose and all solid pipe and you'll need to budget for consumables such as pipe clips, olives, etc.
Even then, you're in for a much rougher ride than with a new kit containing every part you will need.
Unless the above can all be sourced seriously cheap and you have plenty of time and patience for getting it up and running I would go for a new kit. If you're doing enough miles to make LPG worthwhile, you will make your 700 quid back in a matter of months anyway.
Just my humble opinion....  :y
nick v6
thanks for that kev
think i will look at a new kit :y
Quotethanks for that kev
It probably makes more sense unless the 2nd hand one is practically free.
Added to that, there are half a dozen (or more) of us who have installed Teilo's kit so advice is not far away, should you need it.
How much is Teilo charging for a front end, these days?
