Pages: [1] 2 3  All   Go Down
Author Topic: Head gasket progress this weekend  (Read 5969 times)
« on: 09 November 2009, 21:07:52 »
Well, arrived at Blue_dreams place on Saturday AM.
He decided to get some used heads from a breakers, instead of rebuilding the old ones - which was fine with me, as it saved a fair bit of work.
I arrived, and he'd thoughtfully cleaned them up spotlessly clean, and the block, before my arrival - which is a good time saver.
I fitted the exhaust manifold and gasket to one of the heads, and we come across a broken, rounded spark plug, pretty much welded into the head  :( Tried all manner of things, but couldn't get it out with tools available. Got an "irwin" socket to hold well on there - heated it right up - and it still broke 2 extension bars!  :D
Eventually gave up on that idea, I decided it would be as quick to take out the valves from the "new" head, and fit to the old one. so that's what we did - which involved getting a spring compressor, as I didn't take mine.
Anyhow - head build - and they are both now fitted to the car.
Have also fitted the cams, the (correct) shells, cambelt kit, etc.
Compression test is now showing as healthy on all pots  :y
Need to hookup the ancils etc, hopefully next weekend or the one after, and hopefully the old girl will be saved from the graveyard  :)
Re: Head gasket progress this weekend
« Reply #1 on: 09 November 2009, 21:09:19 »
also had to re-fit the later T vents and followers - as the heads supplied were of the older type..
« Reply #2 on: 09 November 2009, 21:09:57 »
excellent progress, how much do you charge for LPG fitting?  ::)
« Reply #3 on: 09 November 2009, 21:28:28 »
To you, I charge:
Accommodation, curry, and beer  :y
« Reply #4 on: 09 November 2009, 21:31:07 »
To you, I charge:
Bargin!
I'll know more by the end of the week, maybe even tomorrow.  :)  :y
If i get what i want, i won't need LPG, if i don't i will!  ;D
« Reply #5 on: 09 November 2009, 21:32:21 »
On a serious note, re LPG...
I'll give you a hand with yours, if you give me a hand with mine  :y
I'm going to LPG the mig as soon as I can really (once I've done the HGs, manifold gaskets, etc)...
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #6 on: 09 November 2009, 21:33:06 »
I'm on the prowl for an LPG kit, waiting for LD to get the info on that other thread.  Then hopefully Kevin Wood could be bribed to help out ::)
« Reply #7 on: 09 November 2009, 21:34:09 »
Kevin and I have done a couple of conversions together now - many of us are very familiar with the Stag kit  :y
« Last Edit: 09 November 2009, 21:34:20 by JamesV6CDX »
Gaffers
« Reply #8 on: 09 November 2009, 21:35:20 »
Yeah but I'll be buggered if I can find one  :-/
« Reply #9 on: 09 November 2009, 21:36:09 »
Sounds like a plan, sure gadget hands could here could be of some use, could be a LPG fitting party, think TB has been mulling it for ages too. Get the BBQ out, some bacon butties on.
Your welcome to use my garage here  :y
My contract is up for renew in 6 weeks, they have to take the decision now to extend it, or offer me perm. If i go perm, fuel no longer counts against my tax, so will need to reduce my fuel bill. Petrol is 110p now, with LPG 57p, kinda makes me think about it every time i drive past  ;D
« Last Edit: 09 November 2009, 21:37:26 by tunnie »
« Reply #10 on: 09 November 2009, 21:36:55 »
Kevin or the Kit?  ;D
Sure we had a good seller who got us the kits?  :-/
« Reply #11 on: 09 November 2009, 21:38:10 »
We have indeed Tunnie (PM pending). I have just sent our supplier my order  :y
Gaffers
« Reply #12 on: 09 November 2009, 21:48:18 »
I seems the supply of these kits is a closely guarded secret :-/
« Reply #13 on: 09 November 2009, 22:13:38 »
Not at all - you can recieve info by PM - we just don't post his details around open forum  :y
Martin_1962
« Reply #14 on: 09 November 2009, 23:24:28 »
After chatting with Kevin, we came to the conclusion the kit is as good if not better than middle market systems.
I think James remembers the OMVL injector failure, I can vouch for Romano injectors not liking high gas pressures, but they are quiet and pretty reliable.
Pages: [1] 2 3  All   Go Up
