Author Topic: chuffed to bits  (Read 4579 times)
sexydaz
chuffed to bits
« on: 14 November 2009, 09:37:41 »
got in mi car this morn and the gearbox is working,beautiful.thanks to all replies  ;D
MickAP
  • South Derbyshire
Re: chuffed to bits
« Reply #1 on: 14 November 2009, 09:45:20 »
Glad all is now ok.
What exactly was the problem, how was it fixed?
Mick
sexydaz
Re: chuffed to bits
« Reply #2 on: 14 November 2009, 10:33:12 »
not chuffed anymore got in car again and back to square one it needs tech 2
Re: chuffed to bits
« Reply #3 on: 14 November 2009, 20:19:47 »
I would clean the switch with contact cleaner and change the ATF and filter.If that doesnt solve the problem then choose between getting it tech 2,d or get one from one of the breakers on here,normally no more than £100, and change the box. :y
« Last Edit: 14 November 2009, 20:21:15 by albitz »
sexydaz
Re: chuffed to bits
« Reply #4 on: 14 November 2009, 21:42:20 »
it is a new box albs,well one from a breakers done 38000 miles and all the oil is new.i can manually select all the gears but in d its in 3rd.changed it yesterday.bloody thing worked this morn got out of car for half hour then got back in and same fault again,somat electrical int it
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: chuffed to bits
« Reply #5 on: 14 November 2009, 21:50:20 »
silly idea, not in snow mode is it
Re: chuffed to bits
« Reply #6 on: 14 November 2009, 22:29:21 »
Snow mode switches itself off above a certain speed. :y
Im no expert but I would be suspecting the switch.
Welung666
Re: chuffed to bits
« Reply #7 on: 15 November 2009, 10:16:46 »
Definately the selector switch. Take it off, clean all the gunge out and spray with lots of switch cleaner (from maplins or similar).
pedroMV6
  • York
  • Der Metzgermeister
Re: chuffed to bits
« Reply #8 on: 15 November 2009, 10:24:55 »
had exactly the same problem with a V*ctra V6 auto I had a few years ago - definitely the selector switch.
All gunked up and shorted out inside, so got another one (not new, mind) and sorted in a stroke. ;)
sexydaz
Re: chuffed to bits
« Reply #9 on: 20 November 2009, 16:40:38 »
i am now chuffed to bits.my maf sensor was putting box into safe mode so new maf and one big smile on my face.one lovely smooth autobox :)
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
Re: chuffed to bits
« Reply #10 on: 20 November 2009, 18:16:25 »
?? How does that work then ?? [smiley=huh.gif]
The Red Baron
Re: chuffed to bits
« Reply #11 on: 20 November 2009, 18:23:21 »
mmmm :-/
sexydaz
Re: chuffed to bits
« Reply #12 on: 20 November 2009, 18:50:21 »
to me its a bad design that any engine fault can put your box into safe mode.it would be far better to put engine into limp mode so you can carry on driving without revving nuts off yer box and burn it out.the codes kept saying maf sensor 0100 and p1700 pending,the p1700 was transmission in safe mode pending the maf replacement.new maf clear codes and hey presto lovely jubbly :)
The Red Baron
Re: chuffed to bits
« Reply #13 on: 20 November 2009, 20:24:02 »
someone will no doubt reply, but i cant see these 2 codes being linked tbh. however the f/lift may be different to what i know with the pre f/l.  ?
sexydaz
Re: chuffed to bits
« Reply #14 on: 20 November 2009, 21:49:52 »
What Does The Air Flow Sensor Do?
The air flow sensor converts the amount of air drawn into the engine into a voltage signal, the vehicles electronic control unit needs to know the air intake air volume to be able calculate engine load in order to determine how much fuel to inject, when to ignite the cylinder, and for automatic vehicles when to shift the transmission
