Author Topic: fitting new wishbones  (Read 5560 times)
MartinP
  • Dudley
    • BMW 320D
« on: 20 November 2009, 22:09:52 »
Bought new wishbones, steering arms and drop links to fit this weekend.
Now I thought that it wouldn't be to bad as I swapped the suspension legs over from the MV6 to the 2.0 CD a few months ago.
Got most the car in the garage, steering arm off in a few minutes, brake caliper off to access the ball joint retaining nut once that was off, I took the drop link off, then came the wishbone!
The bolt through the cross member needed 2 people the other bolt was ok.
BUT  >:( the nut disappeared down the cross member >:(  :-[ :-/ :'( >:(
Tried to get it with a 700mm spring grabby thing, couldn't find it so I am now a nut short :( :( :(
So every thing off.
New wisbone, I fitted the cross member bolt and the front bush bolt, just had to get the ball joint pin in, not very easy at all.
Managed to pinch the ball joint gaiter  :(
Took the front wishbone bolt back out again to get a bit more movement, swapped the gaiter from the old wishbone to the new one and eventually got the thing in.
Fitted the new drop link and steering arm OK, torqued everything up and cleaned up.
After getting the car back on four wheels I put a rubber grommet over the nutless bolt to stop it from dropping out as I had to put the car out front for the night.
I will go the the local Vaux agent and get 2 nuts in the morning.
I then looked on here for a "how to" to see where I went wrong and to see a warning "be careful not to lose the nut"
No one has done the "how to" yet
so! is there an easier way to get the new wishbone on?
and
losing that nut was a bit of a BUGGER.
Martin
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: fitting new wishbones
« Reply #1 on: 20 November 2009, 22:22:01 »
do you mean the rear wishbone bolt? that you lost the nut.
also, hope you didnt torque it up with wishbones hanging?
« Last Edit: 20 November 2009, 22:24:14 by billthebrickie »
Martin_1962
« Reply #2 on: 20 November 2009, 22:28:08 »
Do you need a new rear bolt - free to you if you want it
MartinP
  • Dudley
    • BMW 320D
« Reply #3 on: 20 November 2009, 22:54:46 »
Yes I did  :-[  I'll release it and do both of them on the floor tomorrow.
Thanks
MartinP
  • Dudley
    • BMW 320D
« Reply #4 on: 20 November 2009, 22:56:03 »
Thanks Martin but I need it early doors as I am going out tomorrow evening, so I'll get one from the stealers
« Reply #5 on: 20 November 2009, 23:36:41 »
yeah torque the bolts with wheels loaded, on the ground. Or do them up as tight as possible within limits with wheels on the floor. Then re jack to give more ground clearance to swing the torque wrench if need be. 120 nm then angle tighten 30 degrees then 15 degrees rings a bell, but check that though.
I managed to drop a socket down the sub frame. Very very annoying. Took longer to fish it out than change the wishbone. Needed the socket for the other side....daaaaw!
Martin_1962
« Reply #6 on: 21 November 2009, 00:00:43 »
Special order in bags of three mine were
Martin_1962
« Reply #7 on: 21 November 2009, 20:37:04 »
Did it all go OK?
MartinP
  • Dudley
    • BMW 320D
« Reply #8 on: 22 November 2009, 00:46:43 »
Did it all go OK?
Second side went better, still a nut short (have replied to your email).
Had the tracking done 100 yards down the road to get it somewhere near, I have fitted a slightly undersized bolt to until i get a new nut.
Martin
KillerWatt
« Reply #9 on: 22 November 2009, 10:28:54 »
Waste of money having the tracking done if you have an undersize bolt in there.
« Reply #10 on: 22 November 2009, 11:04:21 »
re getting the nut out, jack one side as high as poss and belt the sub frame with a hammer or mallet. The vibration should make the nut roll to the low side. Then fish it out from there, i had a magnet on a stick. Or try one of those net curtain wires with a small rag on the end and push it through from the other side.
Is there any reason why the bolt cant go in from the top first and put the nut on from the bottom? Cant remember if there is clearance to get the bolt in that way? Just a thought.
    • 530D M Sport, 330i Coupe
« Reply #11 on: 22 November 2009, 11:27:53 »
Thought it was supposed to? That way if the nut falls off the bolt *should* stay in.
« Reply #12 on: 22 November 2009, 12:35:15 »
I too also thought the bolts went in from the top? (although I accept it is more tricky to get the bolts through the bush that way....
Dazzler
  • Haverhill, Suffolk
« Reply #13 on: 22 November 2009, 12:45:16 »
That they do, as a safety thing ;)
MartinP
  • Dudley
    • BMW 320D
« Reply #14 on: 23 November 2009, 00:01:56 »
The tracking was done with the proper bolt in.
The bolts on both sides were ut in from the bottom, it would be extremely difficult to fit the bolts from the top.
I willl try to get the nut out again tomorrow evening.
Martin
