Author Topic: Are V6 cambelt locking kits manufacturer specific?  (Read 6401 times)
Re: Are V6 cambelt locking kits manufacturer specific?
« Reply #15 on: 27 November 2009, 01:07:47 »
If its a v6 engine,rather you than me. :o
« Reply #16 on: 27 November 2009, 09:20:29 »
Just had my timing belt replaced without using a locking tool.
I would get the cam timing checked with a tool ASAP. :y
  • Auckland
    • Mazda MPV
« Reply #17 on: 27 November 2009, 09:41:20 »
Getting the cam timing spot on will probably give more of a performance boost than removing the catalytic converters. Depends how accurate the tippex was I suppose ::)
I did 70,000 miles in my last V6 and changed the cambelt (& tensioners) 3 times without the crank locking tool (because I didn't know any different). Shame I don't still have it, I am curious now about just how far out my cams were :-/
« Reply #18 on: 27 November 2009, 10:59:41 »
With the cam timing out you're going to lose a little performance and economy. If it isn't far enough out to bend the valves the first time it's started I guess there's no permanent harm done.
What worries me most about jobs done without the locking tools is how did they lock the cam pulleys? If it was with a couple of mole wrenches have the pulleys been cracked / weakened?
Alldi
  • Hampshire
« Reply #19 on: 27 November 2009, 21:14:08 »
I had a Sealey VSE130 locking kit that didn't fit, the crank lock didn't latch onto the water pump, it missed by about 1/2", of course I couldn't find this out until I'd done all the dismantling. As a result of all the hassle I'll never buy Sealey tools again! >:(
« Reply #20 on: 27 November 2009, 22:55:02 »
There was a spate of laser ones that did this a year or two back (inaccurate castings). Are you sure it was a Sealey one?
Alldi
  • Hampshire
« Reply #21 on: 28 November 2009, 23:05:44 »
Yep definitely a Sealey one. Laser ones are probably made by the same company but in different packaging
