Author Topic: Drivers heated seat  (Read 2571 times)
stevi1983
  • South West
Drivers heated seat
« on: 05 December 2009, 01:48:40 »
my drivers heated seat does'nt seem to work, is this a common problem and if so is it an easy fix or a garadge jobbie
cheers.......
amba
  • Medway towns
    • German V6
Re: Drivers heated seat
« Reply #1 on: 05 December 2009, 07:48:49 »
Very common fault,especially with leather seats.
It is almost certainly caused by a brake in the thin heater wiring in the seat base pad,but there is also another element in the back...these are both wired together so if 1 section fails the entire heater doesnt work.
Check the fuses first as it may be a simple fix...next check to see you are getting power to the seat elements with a meter...you can also remove the seat back plastic panel and inside you will find a plug connecting the base and back,so should be able to atleast establish where the fault lies.
Then the tricky bit.....if it is fabric covered they are a lot easier and you should be able to slide another seat pad in...if it is leather which seems to be the majority you then have a much bigger job.
I have a similar problem with my drivers seat which is the sports Recaro leather type..my plan is to get a upholsterer to dismantle the leather pads and fit a retro set of waeco after market elements in,as general opinion is the VX type are prone to problems,and are also not cheap.I have held fire on my project at present as £££,s are short ,although it would be the right time of the year to have them working.
Best of luck,but it can be fixed ....at a price ?
unlucky mark mv6
  • tipton,west mids
« Reply #2 on: 05 December 2009, 18:47:16 »
Am i right in saying that there is a pad in the leg atatchmant aswell. :y
p j morgan
  • nottingham
« Reply #3 on: 05 December 2009, 19:03:16 »
i have leather seats and would you beleive mine all work except the drivers seat is it a hard job to sort out ? :-/ :y
unlucky mark mv6
  • tipton,west mids
« Reply #4 on: 07 December 2009, 12:22:48 »
Apparently so,i beleive the pad is stiched to the leather,just waiting till the summer to take mine out and do it.
« Reply #5 on: 07 December 2009, 20:50:51 »
Depends how badly the heating element is burnt. You might get away with cutting out the affected bit & re-soldering it up. Obviously you can't cut miles out!  ;)
If you take the seat out, be careful if airbags are fitted & they're bl00dy heavy!  :-?  :y  :y  :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #6 on: 08 December 2009, 16:40:54 »
I've also had no seat heating driver's side since about 2002. Leather also. But seems too much hassle to fix, and I can't say that I really miss it, especially now that we have global warming. ;D
