Author Topic: Omega LPG Value  (Read 12933 times)
davethediver
  • Blackburn, Lancs.
Re: Omega LPG Value
« Reply #45 on: 12 December 2009, 12:41:02 »
So is it sounds like a good idea to have a spare 2.2 manifold, im definately doing mine in the new year (spring probably). Where do i get a spare manifold and how do i know its a good one?
P.A. Caron de Beaumarchais
Ken T
  • Stockport
Re: Omega LPG Value
« Reply #46 on: 12 December 2009, 17:13:28 »
Use mine. Once Tunnie has fitted the manifold with injectors, his is free and can go to the next person who needs it. As long as I get one back at the end, that's OK (provided the breathers are done !).
Ken
Re: Omega LPG Value
« Reply #47 on: 13 December 2009, 10:30:36 »
Ken
Exactly the theory I've worked on :y :y :y
Re: Omega LPG Value
« Reply #48 on: 13 December 2009, 11:34:47 »
Kevin has very kindly offered to fit the injectors the current spare manifold for my LPG conversion. I hope to convert mine soon, it depends on how busy James is. Annoying i am due to work weekends most of Jan, which is bad for LPG converting, but good for me as weekends is easy work  8-)
Garage should be better for lighting too, James can you do mid-weeks early Jan?
Re: Omega LPG Value
« Reply #49 on: 13 December 2009, 11:48:59 »
If James can't, I may be able to :y
Re: Omega LPG Value
« Reply #50 on: 13 December 2009, 11:49:52 »
Cheers, a plan is formulating  :)  :y
Pages: 1 2 3 [4]  All   Go Up
