Author Topic: TPMS Tyre pressur monitoring system  (Read 3296 times)
bigmac
  • Devon
« on: 13 December 2009, 14:58:05 »
Anyone know if the omega's had this fitted ?
Re: TPMS Tyre pressur monitoring system
« Reply #1 on: 13 December 2009, 15:10:04 »
No they didn't.
bigmac
  • Devon
« Reply #2 on: 13 December 2009, 15:30:59 »
Thanks  :y
« Reply #3 on: 13 December 2009, 15:32:52 »
Nope. Wonder if there is an aftermarket system though?
bigmac
  • Devon
« Reply #4 on: 13 December 2009, 15:47:56 »
Well i'm retro fitting it to my vectra c and i know some one that can make the looms up as its only a couple of wires to add into low canbus system
« Reply #5 on: 13 December 2009, 15:50:33 »
Can't you get one off another vectra or a Saab 93? Some 93 models have em :y
« Last Edit: 13 December 2009, 15:50:46 by LSG_1 »
bigmac
  • Devon
« Reply #6 on: 13 December 2009, 16:28:59 »
I have mate just wondered if the omega's had them fitted as well as they are mostly fitted through out the vauxhall range but under different name's
Plus there more omega's in scrappys by me than vectra c's so it would of helped with replacement parts if i needed any
« Reply #7 on: 13 December 2009, 16:30:01 »
  This doesn't look too bad ..... http://www.tyresave.co.uk/smartire.html
« Reply #8 on: 13 December 2009, 16:31:14 »
Omegas don't have canbus ... so if it's a canbus based system you won't find it on any .. and I've never heard of or seen the system on any omegas....   but I could easily be wrong .. :)
« Reply #9 on: 13 December 2009, 16:38:48 »
Interesting .. but I instantly have 3 questions I can't find the answer to on that site ... :)
1. Does the fitting charge of £50 include re-balancing all 4 wheels ??
2. What does the sensor weigh ?? It must need balance weights fitted diametricaly opposite it, but the idea of 2 lumps of weight acting like a pair of dumbells on my wheels is of concern to me.
3. How long do the batteries last ?? As they are "transmitting" all the time they must run out, and the expense of having to remove the tyres, replace the batteries, replace the tyres and rebalance would have to be added in to the equation.
bigmac
  • Devon
« Last Edit: 13 December 2009, 16:49:57 by bigmac »
« Reply #11 on: 13 December 2009, 16:55:53 »
http://cgi.ebay.co.uk/TYRE-PRESSURE-MONITORING-TPMS-for-VAUXHALL-OMEGA_W0QQitemZ180384976112QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item29ffc84cf0
7yr battery life
And i have the sensors here and they are light weight
OK  thats not too bad then   :y :y
    • 530D M Sport, 330i Coupe
« Reply #12 on: 13 December 2009, 18:28:41 »
They do on the Elite's but only for linking the Infotainment systems.
