Author Topic: Weekend V6 progress  (Read 1882 times)
Weekend V6 progress
« on: 13 December 2009, 20:45:59 »
Heads fully cleaned up and assembled
3.2 manifolds fitted, using genuine multilayer gaskets, and all new studs/nuts.
Heads fitted to car, and torqued down.
Serviced followers fitted (Yes AndyB, Entwood etc, all 24 of them  8-) )
3.0 cams fitted - would have been rude not to  ;) Then rear cover and sprockets fitted.
Spark plugs fitted - needed to be in at this point for cambelt setting up (needs to be done under compression).
Also fitted cambelt kit - a new Genuine item and new water pump. Set up using the SP kit (of course) - no problems there. Outer cover then refitted.
Coolant bridge and stat re-fitted all with new seals. B@stard bolt wasn't too much bother, but had to take me gloves off.
The front cable tray, all front pulleys and aux belt is fitted, as is the lower inlet manifold.
I also re-fitted both cam-covers, with new gaskets and O rings, genuine items.
Then fitted the NS cable tray, and had a general tidy up around the place.
It's pretty much there, just needs some finishing off, such as
*Shave some of the lip of the old cats, to fit the newer type of manifold
* Make up blanking plate for plenum - where EGR used to be. Fuge a bracket to hold the redundant valve, to prevent EML going crazy.
*Vacc pipes to route and new vacc tank to order
* Fit new coil pack and leads when they arrive
*various little connectors/clips/hoses.
* Fit the cats
* Fire 'er up  8-)
Hopefully, one more day will see it done  :y
Re: Weekend V6 progress
« Reply #1 on: 13 December 2009, 20:49:35 »
Good work mate  :y
« Reply #2 on: 13 December 2009, 20:50:12 »
is that all?  ::)  ;D
« Reply #3 on: 13 December 2009, 20:50:29 »
Serviced followers fitted (Yes AndyB, Entwood etc, all 23 of them  8-) ) ......
 :-?  :-?  :-? What've I said?  :y  :y  :y  :y
« Reply #4 on: 13 December 2009, 20:51:29 »
Would I have said a word ...??   Moi ....??   :)
Good work anyway ....  :y :y :y :y
« Last Edit: 13 December 2009, 20:52:23 by entwood »
« Reply #5 on: 13 December 2009, 21:28:54 »
Well done James :y
So we can expect to see it up for sale by christmas then ;D
Marie
    • 2ltr LPG Estate
« Reply #6 on: 13 December 2009, 21:35:59 »
well done! glad to hear it!  :ybet your freezing though mind. lol heres hoping you dont have to go out in the snow next week to finish it.
